Why are starters so weak?
Old May 14, 2008 | 11:30 PM
imzjustplayin's Avatar
Default Why are starters so weak?
I know that you're not suppose to run the starter for longer than 30seconds, but why? Shouldn't a starter be strong enough to continuously be used? I mean isn't it simply an electric motor? Is the reason for this is because they're using a an electric motor that is not really intended for the job in the first place? I was thinking that one could theoretically put a more robust electric motor, run a fuel cutoff switch and then run the "starter" which would basically act as an electric motor, therefore powering the transmission/engine.
Old May 15, 2008 | 05:01 AM
Snafubmx234's Avatar
Default Re: Why are starters so weak? (imzjustplayin)
Starters are high torque electric motors. They draw a tremendous amount of energy over a short period of time, so extended use is not recommended. High torque motors also generate a lot of heat and a starter housing doesn't have an efficient cooling system.
Your idea could work, but it would take quite a bit of energy and a large electric motor (that may be very difficult to mount in the OEM starter location).
liquidzorch
12
Apr 18, 2013 10:28 PM
Tim 59
Honda Civic (2006 - 2015)
Sep 1, 2010 10:30 AM
Importracer_001
Sep 6, 2009 04:49 PM
Chief Brody
Honda Motorcycles
22
Jul 30, 2004 04:00 PM
