SQWEEEK in motor/around it..
Old May 14, 2008 | 10:01 PM
Looneytunerz's Avatar
Default SQWEEEK in motor/around it..
ok soo during high rpms or basically when i floor it...everytime i shift theres a sqweek like a belt is looose...i checked all my belts all seem to be fine only thing i noticed was that the belt on the compressor seems to be tighter then the rest..could this be the problem why it sqweekz at high rpm when i shift
motor is a y8 stock just has its everyday bolt-ons
help needed...
im thinking its belt just stressed....dunno
Modified by Looneytunerz at 9:59 AM 5/15/2008
Old May 14, 2008 | 11:35 PM
bump@!
Old May 14, 2008 | 11:46 PM
anyone!?!!??!??!!?
Old May 15, 2008 | 05:07 AM
sql_civic's Avatar
Default Re: SQWEEEK in motor/around it.. (Looneytunerz)
Well I would bet on the belts. Sometimes they squeak even if they have the proper tension. You may have to replace them. It could also be that you've over-tightened the AC belt and the idler pulley bearings are about to go.
Old May 15, 2008 | 07:24 AM
"normal" driving.....the car is fine....its just when i reallly get on it that the car sqwweekz when i shift...has that loose belt sound........id say from 55-6600 rpm....
the belts have no crack and seem like previouse owner replaced them...
i just got the car recently...
Old May 15, 2008 | 08:02 AM
immajackuup's Avatar
Default Re: (Looneytunerz)
i stop my a/c belt from squeaking at idle by loosen the belt.
Old May 15, 2008 | 09:00 AM
Default Re: (immajackuup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">i stop my a/c belt from squeaking at idle by loosen the belt.
thats the thing tho...mine doesnt sqweek at idle......only at high rev!
Old May 20, 2008 | 12:44 AM
bump BumP bUMp!
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
Project-[R]
Nov 18, 2006 12:44 AM
blueaccord94
May 19, 2005 06:16 AM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
Atiyeh
May 30, 2002 03:34 PM
