Pressure reading on the VAFC at WOT
Old May 14, 2008 | 08:45 PM
Initial_drift's Avatar
Default Pressure reading on the VAFC at WOT
So here is the problem....
At WOT my pressure meter shows at its lowest, -80 to -60 in recent times the number has been averaging around -75. My original avg was -45.
What I want to know is...are the numbers im seeing normal or should they be reading at +/- 0.00 which i have gotten on a few occasions in the past, but very rarely.
Im thinking I might have a small vacuum leak but I checked all my fittings and I didnt notice anything broken or loose.
Does anyone have any advice concerning this issue?
Thanks for your help
Old May 15, 2008 | 09:51 AM
98vtec's Avatar
moderator emeritus
Default Re: Pressure reading on the VAFC at WOT (Initial_drift)
what is the unit of measurement?
Old May 15, 2008 | 10:19 PM
Default Re: Pressure reading on the VAFC at WOT (98vtec)
760MMhg
Old May 18, 2008 | 01:30 PM
Old May 18, 2008 | 01:57 PM
vlang29's Avatar
a vacuum leak won't affect manifold vacuum at WOT.
I would say it's more likely to be a questionable map sensor. Mine reads 16-30 mmHg at WOT
Old May 18, 2008 | 07:31 PM
Default Re: Pressure reading on the VAFC at WOT (vlang29)
Oh ok, ill take a look at the MAP sensor and see if its bad. Thanks.
jdmcivicferio
15
Jul 5, 2005 10:35 PM
Revi
Jul 9, 2004 10:00 AM
_Endless_
May 16, 2003 06:24 PM
Spudddy
May 16, 2003 12:21 PM
glock
Oct 19, 2002 02:29 PM
