TRYING TO FIGURE WHICH TRANNY I HAVE BASED ON RPM, SPEED AND GEAR
having a hard time identifying what tranny i have. i sure its not an ls. dont want to pull tranny and count teeth just to get an answer. my car sits at 3800 rpm in 5th doing 80mph. can you give an educated guess as to which tranny this is. b16 or gsr.
Modified by ivan93egreppin210 at 4:29 PM 5/15/2008
give a few more speeds / rpms in other gears. I am sure this will help those who help you because it is my understanding some 3rd gears are similar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok »</TD></TR><TR><TD CLASS="quote">Seems like you have an LS transmission</TD></TR></TABLE>naw man im sure its not. i rip through the gears pretty fast. ls tranny is wayyyyy longer. i think it might be gsr. can someone with a b16 tranny chime in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE »</TD></TR><TR><TD CLASS="quote">LS 5th:
80mph @ 3400 rpms
70mph @ 3000 rpms</TD></TR></TABLE>
you sure man? that sounds kinda high for an ls tranny. can someone else vouch for his claim?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">My tach is DEAD ON 4k when I'm cruising at 80mph.</TD></TR></TABLE>
what tranny?
80mph @ 3400 rpms
what tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conlyn »</TD></TR><TR><TD CLASS="quote">just for the record
my LS tranny sits my ls/vtec dead at 3k at 60 in 5th
and dead at 5k at 60 in 3rd</TD></TR></TABLE>
this also sounds kinda high for an ls tranny. am i wrong?
I went through 3 transmissions.
GSR at 80 is pretty much right at 4k
B16 tranny at 80 is right at 4300
ls at 80 is at 3700.
check it if you want
http://www.fatboyraceworks.com/gears/
set the redline at the rpm you want to see the speed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok »</TD></TR><TR><TD CLASS="quote">I went through 3 transmissions.
set the redline at the rpm you want to see the speed</TD></TR></TABLE>
ls is not at 3700 at 80mph.........i drive mine on the freeway everyday 80 is around 3400-3500 195/55/15 ls mesh
it's an ls tranny. at 80 mph my gsr tach is straight at 4. my ls would show 3700.
btw, tire and wheel size will not affect the relationship between the displayed rpm and speed. the ecu doesn't know what size tire you have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd »</TD></TR><TR><TD CLASS="quote">i
btw, tire and wheel size will not affect the relationship between the displayed rpm and speed. the ecu doesn't know what size tire you have.</TD></TR></TABLE>
are you on crack
????? of course tire size and rim size well affect rpm and speed. the lower profile your tires the shorter your gears well be. the same goes with if you get a smaller rim(unless you compensate with the tire) your gears well be taller if you get bigger profile tires, too. sames goes for rims here too.
are you on crack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EX_Civic »</TD></TR><TR><TD CLASS="quote">
are you on crack
????? of course tire size and rim size well affect rpm and speed. the lower profile your tires the shorter your gears well be. the same goes with if you get a smaller rim(unless you compensate with the tire) your gears well be taller if you get bigger profile tires, too. sames goes for rims here too. </TD></TR></TABLE>
nope, no crack. you're right, the tire size will affect the relationship between rpm and speed; i said it won't affect the relationship between the displayed rpm and speed. if you were to check the speed of the car with a radar gun, then yes, different tire sizes will give you different speeds at the same engine rpm. however, the ecu doesn't compensate for different wheel/tire sizes.
are you on crack
????? of course tire size and rim size well affect rpm and speed. the lower profile your tires the shorter your gears well be. the same goes with if you get a smaller rim(unless you compensate with the tire) your gears well be taller if you get bigger profile tires, too. sames goes for rims here too. </TD></TR></TABLE>nope, no crack. you're right, the tire size will affect the relationship between rpm and speed; i said it won't affect the relationship between the displayed rpm and speed. if you were to check the speed of the car with a radar gun, then yes, different tire sizes will give you different speeds at the same engine rpm. however, the ecu doesn't compensate for different wheel/tire sizes.
I have an S80 LS tranny and @ 80mph, my car is at 4k, if not a little over. 205/50/15 tires. I hope I have a GSR trans, but I seriously doubt it. 3.5k @ 80mph? I'm always doing 80 and I've never even come close to that. I drive 35 miles each way to work, all highway.
Modified by dc2ls-vtec at 8:32 PM 5/15/2008
Modified by dc2ls-vtec at 8:36 PM 5/15/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ls-vtec »</TD></TR><TR><TD CLASS="quote">I have an S80 LS tranny and @ 80mph, my car is at 4k, if not a little over. 205/50/15 tires. I hope I have a GSR trans, but I seriously doubt it. 3.5k @ 80mph? I'm always doing 80 and I've never even come close to that. I drive 35 miles each way to work, all highway.
Modified by dc2ls-vtec at 8:36 PM 5/15/2008</TD></TR></TABLE>
4k at 80 mph with an ls tranny? impossible. my bro drives a 98 gs, and his car is the same as my 99 ls; 3700 at 80. mine, along with several of my friends gsr's are at 4k at 80 mph. sounds like you do have a gsr tranny.
