1978 Cb750 tire Size ??
Old May 14, 2008 | 08:30 PM
4DRPIMPIN's Avatar
Default 1978 Cb750 tire Size ??
I'm starting a Cafe/whatever cb750 project. I want to go as wide as possible (140 maybe) in the rear . What size will fit without rubbing the chain?
Heres some pics of the bike during disassembly.
Old May 15, 2008 | 03:41 AM
.RJ's Avatar
.RJ
Default Re: 1978 Cb750 tire Size ?? (4DRPIMPIN)
I'm using a 150/80/16 with a 16" harley rim on my CB750 - probably room for more, if I went with a wider wheel. Since you have a '78 you already have the longer/wider swingarm.
Old May 15, 2008 | 09:36 AM
4DRPIMPIN's Avatar
Nice bike! More pics please. Everyone that I see is running a 140 but I wanna go wider. That 150 looks good on your bike.
Old May 15, 2008 | 09:42 AM
.RJ's Avatar
.RJ
Default Re: (4DRPIMPIN)
Whats the stock rim size? The 150 is a little pinched on my bike... Excel makes a ton of rims in whatever size you need, too. I think if I had to do it again I would've gone with 17" rims, more modern rubber and had this shop do the building/truing: http://store.eastcoastwheels.com/
Old May 16, 2008 | 05:49 PM
4DRPIMPIN's Avatar
Stock rim is 3.25 front/4.5 rear . I was thinking about running a 110/80/19 in the front and a 140/70/17 in the rear. Does that sound right?
Old May 16, 2008 | 05:50 PM
4DRPIMPIN's Avatar
btw how much was that chain? Looks good.
Old May 18, 2008 | 09:10 AM
CivicWagonRUS's Avatar
Is that the stock exhaust? You definitely want to hang on to that.
Old May 18, 2008 | 01:12 PM
4DRPIMPIN's Avatar
Yeah its stock, but its rusted out.
Old May 18, 2008 | 02:29 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">Stock rim is 3.25 front/4.5 rear</TD></TR></TABLE>
You sure? I'm pretty sure they're quite a bit narrower than that.
Old May 18, 2008 | 04:59 PM
4DRPIMPIN's Avatar
Actually now that you mention it . I think I misread the manual I have. Does a 2.5 rear wheel sound right?
Old May 18, 2008 | 05:50 PM
.RJ's Avatar
.RJ
Maybe, but there's so many different sizes through the years on those old honda CB's. It may be stamped on the rim somewhere too but I'm not sure.
Old Aug 4, 2008 | 09:31 AM
caferacer's Avatar
Default Re: (.RJ)
Was it difficult to fit the Harley Rims on your CB?
Old Aug 5, 2008 | 12:52 PM
starion88esir's Avatar
Default Re: (caferacer)
All you need is a 16" drop center rim with 40 holes and a spoke kit. Then you just lace the spokes, install new tire and go.
Old Aug 10, 2008 | 07:33 AM
caferacer's Avatar
Default Re: (starion88esir)
Thanks a lot! Do you know where I can find a front wheel that will fit my 1978 cb 750 that has dual discs on the front. Im having trouble finding a dual disc front spoked wheel?
Old Aug 11, 2008 | 01:59 PM
Sure, an early GL1000. I believe 75-77 were spokes, but I could be wrong. I do know for sure that 75 and 76 were spoke rims. Easiest thing to do is swap the entire front fork set up.
Old May 13, 2009 | 08:19 AM
TONUP BLOKE's Avatar
New User
The tire size on the 750 isnt too bad, but if you go any bigger than a 140 they tend to get higher as they get squashed in the rim.
Plus, when the bike goes into a corner, the frame will flex slightly and you may get the tire rubbing on the shock spring.
I have built one or two of these machines and have had a few of these issues before.
I prefer the 130 to be honest.
But thats entirely your own taste my friend.
Peace and Grease
CARPY
Old May 18, 2009 | 09:49 PM
Slippy's Avatar
New User
I have a stock 72 CB750 K2 what is a larger tire that I can fit with out sacrifice of performance on the stock rims...I heard a dunlop gt501 120-90-18 or 130-80-18 does that sound right?
thanx for the sugestions
overtwo
Mar 3, 2008 02:16 PM
The Hooligan
Honda Motorcycles
28
May 26, 2007 08:30 PM
hinds90
Honda Motorcycles
13
Jul 1, 2006 10:55 AM
built562
Honda Motorcycles
10
Jun 7, 2005 03:41 PM
red_f4
Honda Motorcycles
Jul 13, 2004 06:37 AM
