Best Power Option for D15B7
I'm looking for a little more power without doing any internal work or head work. I just put a new head on and the block looked in good shape. I would like maybe 50 more HP. Anyone with a suggestion, I would appreciate it.
If I were to turbo, would replacing the pistons with new stock be worth it?
As you can see I'm a bit of a noob.
d15/16's are difficult to get much power out of without boosting or spending a lot of money, your best option IMO is to swap in a b16/18 you can get a complete b18c1 from hmotors for 2500
listen to these guys, ive owned a DX coupe for years with a b7 small amount of head work, header, exhaust, intake, clutch flywheel blah blah later still slow. lol now i have a swapped hatch and i loves it.
with a bone stock hatch with a swap i easily walk all over my old car
If I had the money and time I would no doubt have that done already. I am just looking for a little more power to deal with all the hills. Its real bad around here. I guess I'm just out of luck with this motor. I'll save up for a B swap.
Money wise...boosting b7 to around 250 hp vs. B swap including install???
Ok so this is probably a stupid question. Does the B16a fit directly into a 92 lx 4 door without changing any mount locations and electronics and such?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxinprogress »</TD></TR><TR><TD CLASS="quote">Ok so this is probably a stupid question. Does the B16a fit directly into a 92 lx 4 door without changing any mount locations and electronics and such?</TD></TR></TABLE>
you will need to run some wiring.
mounts are not moved.
it's a very easy affair, which is why it's so popular.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxinprogress »</TD></TR><TR><TD CLASS="quote">92 lx 4 door</TD></TR></TABLE>
word!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptftw »</TD></TR><TR><TD CLASS="quote">you can always do a mini-me and boost it.</TD></TR></TABLE>
x2
word!
x2
blackriceman
May 11, 2004 08:06 PM
