all motor build woes. need feedback on ITR block
a buddy of mine has been little by little gathering parts for his all motor build. earlier today he sent me a list of what all he has and asked me what else he needed to finish his motor build.
The motor will be going in a 99-00 civic si with the original motor still in it. now my question is, what else does he need to purchase? also what about miscelaneous bolts? should he purchase all of them new or re-use some of the old ones?
here is the list
parts i have so far
Alaniz pnp head PR3
Bare B18C block with main caps
ITR Crankshaft
Woodruff key for ITR crank
Eagle rods
Arias 12.0:1cp. 81.5mm pistons. Custom 8127HP, 331967
ITR crank pulley
ARP Crank bolt
ACL standard bearing kit and thrust washers
ARP headstud kit B18C
Endyn girdle
Valve locks. OEM ITR x32 part number 14781-PR7-A01
NGK V-Power spark plugs R-5671A-8
BDL fuel rail
RC440 injectors
Walbro in tank fuel pump
Toda timing belt
Supertech flat valves. nitride coated
Supertech valve springs SPR-H100DR
Supertech titanium retainers
Rocket motorsports M22x Cams
Toda cam gears
Cometic 81.5mm .051" MLS headgasket.
OEM ITR oil pump
OEM ITR water pump
Spoon spark plug wires
Mugen thermostat
Mugen thermostat switch
OEM honda distributor cap
OEM rotor for distributor
OEM honda valve seals. x16
OEM timing gear pulley Part# 13621-P72-A01
Rubber o-ring timing gear pulley. Part # 19305-PTO-000
Timing plate. Part #13622-PR3-000
Timing belt tensioner 14510-P30-003, Bolt 14513-PK1-000, Spring 14516-PR4-A00, Bolt tensioner 90026-PR3-003
Carbing oil catch tank
Spark plug gasket Part # 12342-PT2-000
Cover water outlet. Part # 19315-P30-J01
RC Engineering Honda clip connectors
Gasket kit Part # 06111-PR4-030
Also I want to use whatever parts that I can off of my original B16A2 including the transmission, clutch and flywheel. In addition to the parts listed above I have the following installed on my B16A2
AEBS intake manifold w/ Hondata IMG
ITR throttle body bored to 65mm
Rage header
Short ram intake with BPi stack
Hondata S200
here is the list
parts i have so far
Alaniz pnp head PR3
ITR Crankshaft
Eagle rods
ITR crank pulley
ARP Crank bolt
Endyn girdle
BDL fuel rail
RC440 injectors
Toda timing belt
Toda cam gears
OEM ITR oil pump
OEM ITR water pump
Mugen thermostat
Rage header
Hondata S200
blykins
39
Jun 1, 2003 10:44 PM
06111pr4030, 12342, 13621p72a01, 19305pto000, 8127hp, 90016pto000, 90232pr7a01, 91, arias, head, honda, pk1, pnp, prelude, pto000, thermostat
