B18A with its cable trans.
Old May 14, 2008 | 07:30 PM
bap168's Avatar
Default B18A with its cable trans.
I'm in the middle of getting all the parts i need to swap my 92 integra's drive train into my 95 EX civic. I need to get everything straight before I do the swap b/c I can't have any down time. The civic is my DD. I know the axles and linkage swap. I already bought a 94-01 integra rear T-bracket and hydro to cable trans. mount. I guess my question is about the driver's side upper mount bracket. I was told I have to buy a 94-01 integra's, but can't I just use the 92's bracket along with its mount? Also will the three upper mounts be enough to hold the motor correctly? I don't know if I can use a 94-01 lower trans. mount on the cable trans. Any info would help
Old May 14, 2008 | 07:36 PM
slacks's Avatar
Default Re: B18A with its cable trans. (bap168)
you mean the mount that goes to the actual engine block on the driver's side? that should be fine.. b18a and b18b are all the same mount.
you're also going to need the lower AC mount and the front transmission bracket..not sure which one you need though..
Old May 15, 2008 | 03:55 AM
bap168's Avatar
Default Re: B18A with its cable trans. (slacks)
I'm not sure that the cable trans. has the mount holes for the lower trans. bracket from a 94-01 integra.
Old May 15, 2008 | 06:03 AM
bap168's Avatar
Can anyone else confirm that the driver's side motor mount bracket will work?
Old May 15, 2008 | 06:41 AM
Andres-eh2's Avatar
the driver side mounts are not the same. i did this swap and ditched the tranny, axles, linkage, and mounts. Used a GSR and B16 tranny and absolutely loved the increased acceleration. all the other parts i used from a 94+ Integra or the 92-95 civic. once i had the correct parts installation is just like any other bseries. 92 integras are Obd1 so keep the ECU and use the civic harness. Just extend the o2 wires and 1 or 2 misc plugs.
Canadian_EF
Apr 7, 2013 02:39 PM
JayDeeMmm
Apr 19, 2012 06:06 AM
barrett_5
13
Oct 4, 2011 05:11 PM
Jared
Oct 29, 2003 07:38 PM
ismkv8s
Mar 9, 2003 08:39 PM
