Vtec Issues H22
Old May 14, 2008 | 07:19 PM
The Destroyer's Avatar
Default Vtec Issues H22
The engine is an internally stock H22, and Vtec will not engage. We have tried almost everything besides tearing the head apart.
I have tons of respect for my tuner (turbogixxer) who has been helping me through this. But I am just throwing this out there in hopes that some other poor soul has had my troubles.
1. No CEL.
2. Plenty of oil.
3. Solenoid works.
3. Will change to hi-cam timing/fuel maps.
4. Recently replaced oil pan.
5. Good amount of oil pressure at the head.
6. No abnormal wear on the cams.
7. Tried other ecu's and even tried to force vtec via neptune.
The only thing left that I plan on trying is a new oil pick up. After that is is taking apart the head.
So if anyone has had any such problems please shoot away.
Old May 14, 2008 | 07:30 PM
2fastGSR's Avatar
King of the One Liners
Default Re: Vtec Issues H22 (The Destroyer)
what system was used to tune it?
Have you tried to turn off the temp requirement? ( with the management system)
If the ECU for some reading is reading false operating temp #s then it may not allow it to engage because it thinks its still cold.
I had problems with vtec engagement and we just disabled the temp reading for vtec engagment and it works fine. . .
Just a thought . . .
Old May 14, 2008 | 07:35 PM
Default Re: Vtec Issues H22 (2fastGSR)
Crome was my current ecu, and I am in the process of switching to Neptune so we tried my Neptune file with no luck.
Im pretty sure we have tried it with temp off.
Old May 14, 2008 | 08:05 PM
98vtec's Avatar
moderator emeritus
try a stock ecu
Old May 14, 2008 | 08:12 PM
PyroProblem's Avatar
Default Re: Vtec Issues H22 (98vtec)
Clogged vtec solenoid screen?
Old May 14, 2008 | 08:20 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: Vtec Issues H22 (PyroProblem)
Is this a jdm motor that was sitting? what oil pan are you using? did you try a different vtec oil press. and solenoid switch? low on vtec fluid?
Old May 15, 2008 | 04:13 AM
obnoxiousls's Avatar
Was this a motor swap in a non vtec car? My buddy put a h22 in his 95 accord and vtec would not engage. He put a brand new vtec solenoid on before tracking the wires to the ecu and the terminal was not plugged in the whole way on the ecu plug. Pushed it in more and vtec was working good ever since. Check the wiring. I doubt its something mechanical
Old May 15, 2008 | 05:25 AM
alterdcreations's Avatar
Default Re: Vtec Issues H22 (obnoxiousls)
rubber o ring in the center cam cap, pins in rockers seized.
how long as the engine sat?
Old May 15, 2008 | 07:33 AM
h22crxpwr's Avatar
Default Re: Vtec Issues H22 (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">rubber o ring in the center cam cap, pins in rockers seized.
how long as the engine sat?</TD></TR></TABLE>
vtec will still engage if you are missing the rubber o ring. i don't have it right now..
however if a pin is missing in the rockers it will not engage..
most likely missing a pin in the rocker if you tried to put vtec on a button and its on in the ECU..
pull the cams out and check each rocker to make sure all the pins are in there.
Old May 15, 2008 | 12:28 PM
Default Re: Vtec Issues H22 (h22crxpwr)
go figure. my stock h22 was missing one(rubber o ring) and I felt their was a problem at engagement....partial engagement if that.
Modified by alterdcreations at 3:23 PM 5/15/2008
Old May 15, 2008 | 01:52 PM
Engine has never sat. Solenoid is clean as can be. Is it normal for healthy h22's rockers to seize?
The car is switching to the hi cam maps. The ecu's iv used are fine.
Old May 17, 2008 | 05:10 PM
OK well we have vtec working. But the only way to describe it is weak. Quiet and not as much power as there used to be.
Now my question is if cam timing can give these results. The low end really hasnt been affected, but I was curious if the timing was slightly off it would be more noticeable on the hi cam?
Old May 17, 2008 | 11:52 PM
88ED8's Avatar
Maybe thats how it's suppose to be...
Old May 18, 2008 | 09:33 AM
Default Re: Vtec Issues H22 (88ED8)
Welp, found a fouled plug today and the car is still kind of quiet but the power is back. I guess the only way to find out is a dyno or going to the track.
Cam and ignition timing is dead on.
I do have an oil pickup on the way as well.
Old May 18, 2008 | 01:59 PM
88ED8's Avatar
I told you to check the plugs
To the track we go
cgaleema
Sep 11, 2011 03:42 PM
subydoored
Feb 18, 2007 10:16 AM
EGcivicBoy
Apr 6, 2006 02:51 PM
booja
Nov 2, 2004 08:26 AM
red92s
Jan 3, 2003 08:17 AM
