few wiring and sensor questions...
Old May 14, 2008 | 05:32 PM
ef dino's Avatar
Default few wiring and sensor questions...
Been workin on an extreme wire tuck on a b16 for a while now. And some sensors just confuse me. This is an obd0 harness that is being modified to obd1 plug.
Green 2 pin plug on back of block above oil filter: one wire, red/blue stripe. WHat sensor is this?
Theres a plug under that one with a rubber boot around it. If you take the boot off theres two 1 pin plugs. Ones yellwo/green and the others black.. Which one goes on the left if your looking at the back of the block from the firewall... Is this the fan switch?
A little above that 2 wire boot plug is a 1 wire plug again... is this the knock sensor?
Next plug im stuck on is on the back of the intake mani. Its a two wire black plug, goes on the aluminum thing on the back of the intake mani.. EVAP SOLENOID? ORR IDLE AIR CONTROL Valve?
Last but not least is a one pin plug under the dizzy. Right where the head meets the block. yellow/ green stripe, which sensor is this?
Old May 14, 2008 | 11:58 PM
ef dino's Avatar
Default Re: few wiring and sensor questions... (ef dino)
come on wiring gurus.
Bjm1118
Mar 17, 2019 11:51 AM
chrisfromsrq
Jan 24, 2010 08:37 AM
namewasdallas
11
Jan 7, 2009 01:14 PM
turbo-crx
Sep 30, 2008 10:00 AM
jwbnavy
Dec 4, 2007 02:20 PM
