help!!! crazy vibration problem
Old May 14, 2008 | 05:01 PM
jeremiah963's Avatar
Default help!!! crazy vibration problem
so last friday i was drivin my car on 71 about 70mph and all of a suddin i had a horible viberation... it felt like the front end was going to fall off.... i checked ball joints and tie rods. replaced both outers and the stearing rack due to a lot of fluid leaking from the rack... still had the problem!!!! put it back on jack stands and put it in gear and reved it to 2k rpms and noticed the motor was moving from left to right..... i already had some new mounts to replace the egay mounts that came in the car... and the motor still moves... the mounts i put in are inovative mounts with the 75a bushings.... there sounds like somekind of noise coming from the tranny but not sure.... any help would be awsome..... thanks jeremiah
for those wondering its a 90 crx si with a b16a swap
Old May 14, 2008 | 06:03 PM
draperj09's Avatar
Default Re: help!!! crazy vibration problem (jeremiah963)
Tires?
Old May 14, 2008 | 06:13 PM
Default Re: help!!! crazy vibration problem (draperj09)
the tires are good still pretty new checked them over and no broken belts!!!!! my buddy talked to a few techs at honda and there thinking a bad tranny! maby bad input shaft idk. any other sugestions
Old May 14, 2008 | 06:14 PM
grog's Avatar
is the rear mount okay? take a look at all of them and make sure they are tight and not broken.
Old May 14, 2008 | 06:50 PM
Default Re: help!!! crazy vibration problem (grog)
all the mounts are brand new bolts are all tight just put the mounts in today
Old May 14, 2008 | 08:58 PM
K20EF8Dx's Avatar
motor is shifting violently left and right not back and forth like a motor mount problem. i think bad main or counter shaft!
Old May 15, 2008 | 05:18 AM
Default Re: help!!! crazy vibration problem (K20EF8Dx)
thats what im thinking but i guess well find out any other ideas guys?
Old May 15, 2008 | 04:21 PM
Old May 19, 2008 | 10:00 PM
K20EF8Dx's Avatar
well we solved the problem we swapped trannys and it wasnt that it ended up being a half shaft bearing went bad.
bodiez
27
Apr 24, 2009 05:16 AM
HackAbuse
Mar 18, 2007 08:35 AM
b20vtecv8killer
Aug 20, 2004 09:05 PM
will
Mar 15, 2004 08:15 AM
26
Apr 30, 2002 05:39 AM
