Help:96 Civic SOHC Sparks gets Fuel Cranks Wont Start
Old May 14, 2008 | 04:54 PM
NGAMotorsports's Avatar
Default Help:96 Civic SOHC Sparks gets Fuel Cranks Wont Start
I tried to search but found nothing. I have a 96 Civic DX SOHC that I turned out of the store last week and it died wouldnt start.
I have since changed the Cap and the ignition coil. I didnt replace the rotor yet. The first time I cranked it over after I installed the new parts the car nearly started. Checked all 4 plugs and they are all getting sparks.
Any ideas what it could be. The car is also getting fuel as the plugs smell like fuel.
I also started started fluid in the intake and nothing.
Any help would be great.
Thanks
Old May 14, 2008 | 08:18 PM
96plusf20bb's Avatar
Default Re: Help:96 Civic SOHC Sparks gets Fuel Cranks Wont Start (NGAMotorsports)
well since you said ur getting fuel and spark. lets go back to basic
4 things an engine needs to run are:
1.air
2.fuel
3.compression
4.spark
we have got two of them so lets look for the ones missing start with the easiest one check your air filter make sure its not being plug by anything very rare but it happens, after you comfirmed the you are getting air, do a compression test if all the cylinders pass the compression test and u make sure that all ur sensor(CKP, CAM, TPS, MAP to name a few) are working and tightly plug the check timing, you might have had jumped a teeth or too. good luck
Old May 15, 2008 | 05:26 AM
bOOsted_D16's Avatar
sounds like it jumped time
Old May 15, 2008 | 07:00 AM
01S2king's Avatar
crack the fuel pressure checker nut and crank engine over to see if fuel is actually getting to fuel rail.
also make sure that the ignition rotor is tight and not just flopping around.
Modified by 01S2king at 1:30 PM 5/15/2008
Old May 15, 2008 | 05:02 PM
Default Re: Help:96 Civic SOHC Sparks gets Fuel Cranks Wont Start (01S2king)
New rotor is installed, battery fully charged car nearly started, actually sputtered a little bit.
Any more ideas what the problem could be.
Old May 16, 2008 | 06:50 PM
01S2king's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NGAMotorsports &raquo;</TD></TR><TR><TD CLASS="quote">New rotor is installed, battery fully charged car nearly started, actually sputtered a little bit.
Any more ideas what the problem could be.</TD></TR></TABLE>
remove the cover around the steering wheel and look at the ignition switch. see if it is burnt and brown
Old May 16, 2008 | 06:54 PM
geebs's Avatar
remove your valve cover and remove the timing belt upper cover. move the crank pulley to top dead center.. check the cam timing.. it sounds like its off.
when you get it to top dead center and the UP mark on the cam gear is upside down, spin the crank another revolution. make sure the lines on the cam gear are inline with the cylinder head
Aaron Weise
Jul 9, 2018 09:19 AM
Wrona
Feb 6, 2011 02:56 PM
ketchup
Jan 30, 2009 01:55 PM
hayn_integra
Oct 23, 2007 10:09 AM
kasso
Mar 23, 2006 01:38 PM
