prelude brakes on DA question
i have a 90 DA and read an article in honda tuning about using prelude rotors and legend calipers as a poor mans type-r brake swap...... does anyone know the year and model rotors from a prelude and the year of legend? i thought it was 94 prelude but cant remember! THANKS
there's a tread on here somewhere. but yeah you gotta get prelude vtec rotors 92-96 and get them re drilled to 4x100. fast brakes sells rotors that are the same size and are 4x100.
that thread isnt right...... i think it was a 94 prelude that already uses the 4x100 bolt pattern.... and it was legend rotors that were a direct fit...... ithey even said something about using NSX rotors in the place of the legend ones... if anyone has the issue of honda tuning im talking about i would appreciate the info
yes this is the poor man's upgrade... but its a factory upgrade
. you could get the single piston caliper(accord v6, accord wagon, regular legend), i dont remember the size... or you could get the dual piston of a legend GS coupe brakes of a '94 i believe... and yes its worth it, stopping power is increased much. my da is a rs non-abs, and it seems to me that the brake are harder to lock now
some sites tell you do modify (shave) the caliper but you could use ( I did) a 1/16 or 1.5mm spacers between the spindle and the rotor... in my opinion i think its better than to change the integrity of the caliper...
on da's the brake master cylinder is a 15/16 and the type-r is 16/16, i dont believe it is worth it... but its up to you...
and you could do the same for the rear brakes... these rotors and calipers are much easier to find...
. you could get the single piston caliper(accord v6, accord wagon, regular legend), i dont remember the size... or you could get the dual piston of a legend GS coupe brakes of a '94 i believe... and yes its worth it, stopping power is increased much. my da is a rs non-abs, and it seems to me that the brake are harder to lock now some sites tell you do modify (shave) the caliper but you could use ( I did) a 1/16 or 1.5mm spacers between the spindle and the rotor... in my opinion i think its better than to change the integrity of the caliper...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmda90 »</TD></TR><TR><TD CLASS="quote">that thread isnt right...... i think it was a 94 prelude that already uses the 4x100 bolt pattern.... and it was legend rotors that were a direct fit...... ithey even said something about using NSX rotors in the place of the legend ones... if anyone has the issue of honda tuning im talking about i would appreciate the info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmda90 »</TD></TR><TR><TD CLASS="quote">the caliper stuff sounds right but isnt there a prelude that had 4x100 pattern???? i might have misunderstood?!?!?!</TD></TR></TABLE>
Wrong. They're 4x114.3
92TypeR
Feb 15, 2006 10:28 PM
