S/B 08-001 Uneven or Rapid Tire Wear
Just a note we have been getting quite a few of these cars in the dealership lately, many are just over their factory warrenty for milage etc. So catch it earlier if you can it will save you money if you can get the parts/ labor warrantied.
Applies to:
2006-07 Civic 2-Door - All Except Si and Honda Accessory HFP Package
2006-07 Civic 4-Door - All Except Si
2006-07 Civic Hybrid - All
2008 Civic Hybrid - From VIN JHMFA3...8S000001 thru JHMFA3...8S010456
SYMPTOM
The customer may complain of uneven or rapid rear tire wear, a roaring noise from the rear, or a vibration at highway speeds.
PROBABLE CAUSE
The combination of the tires and the rear suspension geometry may cause rapid and uneven tire wear. Tires in an advanced stage of this diagonal or inner edge wear may cause vibration and/or a bad bearing type noise.
CORRECTIVE ACTION
Install a rear upper control arm kit, replace the flange bolts and worn tires, and do a four-wheel alignment.
PARTS INFORMATION
Rear Upper Control Arm Kit:
P/N 04523-SNA-A00, H/C 8820698
Flange Bolt (four required):
P/N 90397-SNA-A00, H/C 8481012
Flange Bolt (two required):
P/N 90396-SNA-000, H/C 8178576
Applies to:
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
PARTS INFORMATION
RanCRX
Feb 24, 2012 10:59 PM
xxpaulcpxx
Honda Civic (2006 - 2015)
10
Jul 29, 2010 09:17 AM
