JDM b18c NEED HELP!!!
Old May 14, 2008 | 01:34 PM
Unknown Racing's Avatar
Default JDM b18c NEED HELP!!!
I recently purchased a 99 GSR and my motor threw a rod due to a bad oil pump. so I purchased an OBD2 b18c. I got the motor and it was from an automatic b18c. so I transferd my intake manifold from my blown motor and when I was transfering my engine harness I noticed I could not find where one plug goes. there are no sensors showing anywhere. its in the back of the motor behind the intake manifold by the alternator. so I just left it and hoped it would be ok... after all thats said and done I started the car yesterday and its throwing a code p1337 Crankshaft Speed Fluctuation Sensor No Signal and my idle is rough. also the car doesnt seem to be hitting vtec. any help would be appreciated. im using my stock obd2 ecu and the usdm wiring harness anything else I should know?
Modified by Unknown Racing at 3:27 PM 5/14/2008
Old May 14, 2008 | 01:49 PM
Rickdrizzle's Avatar
I'd also like to know.
Old May 14, 2008 | 03:38 PM
Default Re: JDM b18c NEED HELP!!! (Unknown Racing)
bump
Old May 14, 2008 | 03:55 PM
Dogginator's Avatar
Daisy... Daisy...
JDM engines didn't have that sensor.
Read this:
http://technet.ff-squad.com/ckftrick.htm
Old May 14, 2008 | 05:55 PM
Default Re: JDM b18c NEED HELP!!! (Dogginator)
thank you for answering that. Do u know if that would cause my car to not hit vtec?
Old May 15, 2008 | 02:01 PM
bump for my car not hitting vtec
Old May 15, 2008 | 03:12 PM
Dogginator's Avatar
Daisy... Daisy...
Most likely.
Old May 15, 2008 | 03:41 PM
all-mtr-teg's Avatar
No crankshaft position sensor on the jdm block, therefore CEL. Your gonna need to get an OBD2 oil pump, a crankshaft position sensor and probably an OBD2 lower timing belt cover.
Old May 15, 2008 | 04:26 PM
310Integra's Avatar
you can get the the type r oil pump. should probally fix your problem. and I'm still using the jdm automatic intake manifold. hopefully that helps.
Old May 15, 2008 | 04:28 PM
Default Re: JDM b18c NEED HELP!!! (310Integra)
Type R and OBD2 GSR oil pump = same part number.
Modified by all-mtr-teg at 5:48 PM 5/15/2008
Old May 15, 2008 | 04:46 PM
310Integra's Avatar
Default Re: JDM b18c NEED HELP!!! (all-mtr-teg)
true, the guy at the swap shop just marked it down as that.
Old May 15, 2008 | 04:47 PM
For how much?
Old May 15, 2008 | 04:58 PM
310Integra's Avatar
150 installed
Old May 15, 2008 | 05:01 PM
was he already building the block?
Old May 15, 2008 | 05:14 PM
310Integra's Avatar
what do mean, the b18c i bought? I was ask if it was going to be going on a obd2 car, I said yes and then he said I would need an oil pump or else my engine wouldnt run as good. So all the guy did was installed the oil pump in for me so I could just do a straight in swap. So that part (oil pump) cost me $150 including the labor. Everything else I did.
rob-smash
Aug 24, 2009 10:52 PM
mugenintegra16
Nov 23, 2008 06:59 PM
98 gsr teggy
Apr 19, 2007 08:38 AM
