leaking tranny fluid from the shift rod. best fix?
Old May 14, 2008 | 01:05 PM
blackeg's Avatar
Default leaking tranny fluid from the shift rod. best fix?
the rubber boot that covers up the bitch pin on my gsr trans is collecting tranny fluid. i believe its coming out of the trans where that shift rod goes into the back. is there a rubber seal in there? can that be replaced without removing the trans and cracking the case open? any insight is helpful. thank you
Old May 14, 2008 | 09:06 PM
mixster's Avatar
Default Re: leaking tranny fluid from the shift rod. best fix? (blackeg)
yea mine did tha same thing. theres a rubber seal in there. really easy to get to and change. think it was like 10 bucks or so. should take like 15 min to do. just make sure the shift shaft is clean and put the new seal in. then no more leak.
litoekneeil
Transmission & Drivetrain
Jun 8, 2010 08:53 AM
Slosc2
14
Apr 22, 2009 11:07 AM
busychild
Feb 27, 2006 12:23 PM
SandFireTypeR
Nov 9, 2004 03:58 PM
X2BOARD
May 10, 2003 09:29 PM
