slim fans on a EG
i need to buy 2 fans because mine just went out (condenser and radiator.) since im replacing them, i thought why not replace them with better flowing, thiner fans right? what do you guys think?
would the 12" be too big or should i go with a 10"?
how much more cfm's do the get over stock?
any fans that will fit right on the stock locations?
thanks for your guys time and patience!
if your running a stock motor just use a stock fan... dont waste the money your not going to make your car faster by keeping it cool. i use a d16 fan on my b16... works perfect. just my opinion
12 will fit.. I run a 14 inch permacool on mine. For the CFM difference, it varies depending on the Fan make and model. Stock is 950CFM I believe.
-platinum
-platinum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">12 will fit.. I run a 14 inch permacool on mine. For the CFM difference, it varies depending on the Fan make and model. Stock is 950CFM I believe.
-platinum</TD></TR></TABLE>
o wow i thought the stock ones had more cfm? where can i go check it out to confirm this?
3a_eg_hatch
Jun 17, 2007 03:48 PM
Unjockable
Mar 11, 2005 01:07 PM
