Y1 Transmission, Where to get Replacement Parts?
The sticker on the case itself says its a Y1, i counted
the teeth on the gears.
12, 19, 24, 29, 31: 64
I have no idea where to find parts for this transmission i need info on where i can buy this parts..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agnom »</TD></TR><TR><TD CLASS="quote">Try http://www.gearspeedinc.com/</TD></TR></TABLE>
I was looking more into what car released in the usa could i use the parts of to fix it
i think they're more into the hydro tranny parts.. Ill give them a call maybe they can help me
There is no U.S. equivalent. You can get synchro's and sliders out of a 90-91 integra but the gear ratio's are all different.
what about mainshaft bearing?
i notice when i counted the teeth i was surprised how much different the y1 is, and not that but this Y1 did not have lsd, so i guess not all y1's have lsd?
I know that the B-series input shaft size changed in 1992. It's 1mm larger than the 88-91 B-series (in the US anyway). Isn't our YS1 tranny similar to the Y1?? I know the lsd's can be swapped out....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy »</TD></TR><TR><TD CLASS="quote">I ordered the bearing off a 90 ls integra, hopefully it works</TD></TR></TABLE>
I believe most, if not all, of the bearings and seals are from a 90-91 LS tranny. As far as synchros and jdm only stuff, gearspeed should have u covered.
And yes, not all Y1's are LSD equipped. It was optional.
595, cars, gears, honda, kit, parts, rebuilding, replacement, seal, seals, synchros, trans, transmission, transsmission, y1, year
