KNOCKING please help
Old May 13, 2008 | 10:44 PM
del sol gsr's Avatar
Default KNOCKING please help
i have a del dol i put a gsr in it and it started making a loud knocking noise so i redid my valves checked bottom end and was all good so i played with it for 2 more days and pulled it out and put a new built gsr in it and used no parts off the old gsr and the it is knocking i changed the ecu many times new wire harn new injectors about 3 times the sound is like there is a bolt in the head or like you hit the head with a hammer im lost please help
Old May 13, 2008 | 11:09 PM
98vtec's Avatar
moderator emeritus
Default Re: KNOCKING please help (del sol gsr)
describe what a "built" motor is.
Old May 13, 2008 | 11:13 PM
prettylew's Avatar
did u adjust the valve lash? check your lost motion assemblies? and if you dont know what im talkin about then please bite the bullet and take it to a professional
Old May 13, 2008 | 11:25 PM
Default Re: (prettylew)
yeah i chked them on bouth motors and also i have redone the valves on bouth motors
Old May 13, 2008 | 11:27 PM
i have wiseco pistons and rods 5 angel valve job on a b16 head with itr cams golden eag intake
Modified by del sol gsr at 12:42 AM 5/14/2008
Old May 13, 2008 | 11:57 PM
Thrizzle's Avatar
* B A N N E D *
Default Re: (del sol gsr)
whats your PTW clearance? Bearing clearances? Tuned?
Old May 14, 2008 | 06:52 PM
Default Re: (Thrizzle)
HELP PLEASE im lost
Old May 14, 2008 | 09:16 PM
prettylew's Avatar
so you took out the knocking motor, and put a TOTALLY different motor in it? like different block and different head? and it is STILL knockin?
Old May 14, 2008 | 09:38 PM
98vtec's Avatar
moderator emeritus
Default Re: KNOCKING please help (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">describe what a "built" motor is.</TD></TR></TABLE>
please answer questions as they are given.
Old May 14, 2008 | 11:26 PM
yeah i changed motors and used no same parts im lost
Old May 14, 2008 | 11:29 PM
new rods pistons cams all aftermarket
Old May 15, 2008 | 06:17 AM
prettylew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol gsr &raquo;</TD></TR><TR><TD CLASS="quote">yeah i changed motors and used no same parts im lost
idno what to tell u in that case. i mean if u used a COMPLETELY different engine, and still had the same noise. then i guess its not the engine.
Old May 15, 2008 | 08:12 AM
MikeSarr_GSR's Avatar
Default Re: KNOCKING please help (prettylew)
is the knock slow or quick? is it like knock knock at idle or is it gone at idle and then when you gas it does it dramatically increase its speed? sounds like to me that you have the cam oiler caps installed incorrectly and the cams are galling into the head.
and if you dont know what that means... take the car in before you lose your investment
Old May 15, 2008 | 09:01 AM
Thrizzle's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrizzle &raquo;</TD></TR><TR><TD CLASS="quote">whats your PTW clearance? Bearing clearances? Tuned?</TD></TR></TABLE>
Old May 15, 2008 | 07:39 PM
it only knocks at idle on this motor and on the stock gsr it knockes at around 3500rpm i think im going to swap it again
Old May 15, 2008 | 07:49 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol gsr &raquo;</TD></TR><TR><TD CLASS="quote">new rods pistons cams all aftermarket </TD></TR></TABLE>
that doesnt tell me anything man. Do you realize how many different configurations of cranks, rods, pistons and cams that you could possibly put into a B series?
there is no way we can help you unless you give us the information we need to help you.
what is the compression of the motor?
what are the bearing clearances?
what is the piston to wall clearance? if known...
Old May 15, 2008 | 08:10 PM
Fat Chick Magnet's Avatar
Is your knock sensor working?
i once thought my motor was knocking, but i found out it was the belt tensioner making a noise at idle and above 3k rpm...made me **** bricks..
Old May 15, 2008 | 09:13 PM
2fastGSR's Avatar
King of the One Liners
Default Re: (Fat Chick Magnet)
This thread has to be a joke.
No one can be this mentally challenged and still be able to register for HT.
Old May 15, 2008 | 09:17 PM
Combustion Contraption's Avatar
Default Re: (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">This thread has to be a joke.
No one can be this mentally challenged and still be able to register for HT.</TD></TR></TABLE>
Sadly, there is no competency test. This plankton could have been weeded out.
Old May 15, 2008 | 09:19 PM
b19coupe's Avatar
thread.
hylaxrng
Dec 17, 2013 11:03 PM
Trung Nguyen
41
Jul 26, 2012 10:56 AM
blackhatchb20
11
Jul 1, 2006 11:43 AM
2-logicl
20
Jun 21, 2006 03:53 AM
SR20DETg20girl
Nov 23, 2005 11:16 PM
