Help!!! My car is misfiring 3 cylinders....
Old May 13, 2008 | 09:51 PM
SI_frankenstein's Avatar
Default Help!!! My car is misfiring 3 cylinders....
Well guys i have a 00 si ls/vtec and i need to pass NC inspection but my car is misfiring wich is codes 71,72,73. Well i just bought a brand new dizzy and new injector seals and the ckf sensor changed fuel filter, and sparkplug wires and plugs. At idle it makes this little popping noise which comes from the intake, the motor only misfires at idle from what i can tell. I need help please
Old May 14, 2008 | 04:51 AM
steven_highet's Avatar
Default Re: Help!!! My car is misfiring 3 cylinders.... (SI_frankenstein)
Is it hunting for the idle?
You might have a overly lean condition at idle which is causing a lean misfire.
Have you tried to retard the ignition?
Or even try and turn up the idle screw and move it to a higher rpm.
Misfiring code 71,72 and 73 is misfiring on 1,2 and 3.
Have you done a compression check?
Modified by steven_highet at 5:59 AM 5/14/2008
Modified by steven_highet at 6:01 AM 5/14/2008
Old May 14, 2008 | 09:25 PM
Default Re: Help!!! My car is misfiring 3 cylinders.... (steven_highet)
The idle is not hunting and i have not retarded timing but i did raise idle and my compression id good, its making a weird noise through the intake though, which sort of sounds like you can hear it misfire through the intake... ? Im going to replace map sensor and injectors and try a valve adjustment 2 see if that helps???
Old May 15, 2008 | 01:43 PM
WhiteOnRice's Avatar
My car is misfiring 3 cylinders and this guy too: https://honda-tech.com/zerothread/2300423 :s
Old May 15, 2008 | 02:42 PM
Crazydave's Avatar
Default Re: (WhiteOnRice)
Do you have the spark plug wires going from the right terminal on the distributor to the correct cylinder..
slow_low_eddie
Dec 29, 2013 05:54 PM
90crxsib16
Jul 21, 2004 03:51 PM
Gump
12
Dec 5, 2003 02:11 PM
