help with cracking sound coming from the front wheel
Old May 13, 2008 | 09:09 PM
pannito's Avatar
Default help with cracking sound coming from the front wheel
When I turn my steerig wheel right/left I hear a cracking sound coming from the left front wheel.
What can it be?
Help plsss!!!!!!
Old May 13, 2008 | 09:24 PM
I AM WEASEL's Avatar
possibly something with the axle?
Old May 13, 2008 | 09:29 PM
pannito's Avatar
Default Re: help with cracking sound coming from the front wheel (pannito)
I don't think so, because it does it when the car is still too
Old May 14, 2008 | 03:03 AM
Tiger_Si's Avatar
if you are lowered and no camber kit.
it is the wheel bearing, change it, before it deforms the front knuckle.
Old May 14, 2008 | 07:14 PM
pannito's Avatar
Default Re: help with cracking sound coming from the front wheel (Tiger_Si)
ok, thx!
Old May 14, 2008 | 08:12 PM
pannito's Avatar
But can a bearing have a cracking sound like when you open an old door?
Old May 15, 2008 | 04:28 AM
Tiger_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pannito &raquo;</TD></TR><TR><TD CLASS="quote">But can a bearing have a cracking sound like when you open an old door? </TD></TR></TABLE>
what?
Old May 15, 2008 | 05:40 AM
coolhandluke's Avatar
This wasn't a symptom in your OP, so to us it is a new symptom. I would lube the door hinges and see if it still makes the noise. Then, back to the big issue- what could possibly be your front wheel bearing.
Old May 15, 2008 | 06:45 AM
CW-ITR's Avatar
It's more like the axle is going bad. Park the caR with the key in the "on" position so that you don't lock up the steering wheel. Have someone turn the steering clock to clock with you under neath the caR. You should be able to tell where the cracking noise come from.
Old May 15, 2008 | 03:20 PM
Kenso's Avatar
HT White Ops
Do you mean a creaking noise? Could be a balljoint. You may need to pick up a mechanic's stethoscope and check for the source of the noise in different spots while someone else works the wheel back and forth.
Old May 15, 2008 | 06:14 PM
pannito's Avatar
Default Re: help with cracking sound coming from the front wheel (Kenso)
ok, thx.
Old Jul 9, 2008 | 12:16 PM
ialafroz's Avatar
I have the EXACT SAME problem.... if some realizes what the issue is please let me know (ialafroz@hotmail.com).. It will be really appreciated. I will checking the forum in a regular basis as well...
thanks all !
leoaa777
Jan 5, 2008 06:49 PM
Don Jefe
Apr 12, 2006 01:31 PM
krispyaccord
Dec 3, 2005 02:16 PM
noob
Jan 31, 2005 03:38 PM
Slow Egg
Dec 19, 2003 07:52 AM
