B16a tranny (cable) spool in a 92-93 GSR tranny (cable)???????????
Old May 13, 2008 | 02:47 PM
integrawow's Avatar
Default S1 B16a tranny (cable) spool in a 92-93 GSR tranny (cable)???????????
Hey, from what I understand the 92-93 GSR cable tranny (YS1) is the only cable tranny that uses the same internals as the hydro B16 tranny's.
I have a spool that was ordered for an LS or B16a cable tranny from Richmond. However, I plan on getting the cable GSR tranny. Will the spool fit this particular GSR tranny?
Please let me know.
Old May 13, 2008 | 03:29 PM
tagperformance's Avatar
If the spool is for a cable s80/y1 or jdm s80 it will not fit the bigger differential ring gear. I beleive majority of the small spline cable trannies all use similiar parts like the usdm 1990-91 acura integra ls tranny
Old May 13, 2008 | 04:02 PM
integrawow's Avatar
^^^^^ I'm confused.
Just in case I explained it wrong:
The spool I have is for either the B18A1 cable tranny, or it is for the S1/J1 B16a JDM cable tranny.
I want to replace my grinding S1 tranny with a USDM YS1 tranny from a 92-93 GSR integra. However, I don't know if I can still use the spool I already have.
Old May 13, 2008 | 04:11 PM
Turbogixxer's Avatar
Default Re: (integrawow)
You would be wrong. Smaller shaft cables (90-91) do not use hydro sets. 92-93 can use hydro sets.
Diffs are a differnt thing
Old May 13, 2008 | 04:18 PM
integrawow's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">You would be wrong. Smaller shaft cables (90-91) do not use hydro sets. 92-93 can use hydro sets.
Diffs are a differnt thing</TD></TR></TABLE>
If you're refering to gearsets, then we're talking about two different things. I'm refering to spools.
So can I use my spool?
Modified by integrawow at 5:31 PM 5/13/2008
Old May 13, 2008 | 04:27 PM
integrawow's Avatar
bump &lt;-- I probably shouldn't have done this, but i'll take my chances. I need to know this info at least by tomorrow morning.
Old May 13, 2008 | 04:33 PM
DaveF's Avatar
im pretty sure the spool will still work.
Old May 13, 2008 | 04:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">
So can I use my spool? </TD></TR></TABLE>
I never installed one, so I can not give you a 100% answer, but I would imgane it would. Clearance problems with the LSDs can be solved by shaving the case.
Old May 13, 2008 | 04:51 PM
integrawow's Avatar
The main thing that scares me is that exospeed sells a spool for both the b16a/ls and they sell one for the B18c/gsr. However, does this gsr include the 92-93 gsr?
Crazy **** man. Honda's ftw. LOL
Old May 13, 2008 | 05:01 PM
integrawow's Avatar
Oh yeah. I found out what I needed to know. Yep, you guys were right. The one that would be different would be the 94+ GSR tranny. The rest of them are pretty much compatible with one another as far as the spool goes.
Thanks for all of the replies.
LSpimpTEC
Jun 15, 2004 07:38 PM
AllMotorMark
Apr 9, 2002 12:25 PM
