Do the springs/retainers need to be upgraded too?
Old May 13, 2008 | 12:54 PM
StraightNoChaser's Avatar
Default Do the springs/retainers need to be upgraded too?
I've got a B18B from a 96 Integra in my Del Sol. Several days ago it jumped timing by three teeth and bent a few valves. I'm going to have the valves replaced because the head seems perfect otherwise. Anyway, what I'm getting at is this: I plan on buying the Crower 402s with adjustable cam gears. I don't want to buy springs and retainers unless I have too. Do you guys, who know far more about this then me, think that's safe?
Old May 13, 2008 | 12:56 PM
Rickdrizzle's Avatar
Since you're changing the cams and camgears out, I think it'd be a good idea to swap out the valvesprings also, for peace of mind.
Old May 13, 2008 | 01:29 PM
Default Re: (Rickdrizzle)
You're supposed to tell me what I want to hear. Something along the lines of "You'll be fine....no need for springs.." Thanks for the help, I'll start looking around for springs now.
Old May 13, 2008 | 01:31 PM
Default Re: (StraightNoChaser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightNoChaser &raquo;</TD></TR><TR><TD CLASS="quote">You're supposed to tell me what I want to hear. Something along the lines of "You'll be fine....no need for springs.." Thanks for the help, I'll start looking around for springs now.</TD></TR></TABLE>
well, i'm just telling you what i would do.
for example, take a look at the gsr owners who wants to get itr cams. it's recommended that they get the itr intake valve springs and push the gsr intake valvesprings over to the exhaust side.
but some people get away using the stock gsr valvesprings and not pushing it past the factory redline.
Old May 13, 2008 | 01:52 PM
mc-integra111's Avatar
Default Re: Do the springs/retainers need to be upgraded too? (StraightNoChaser)
Ask Crower, they'll know.
Old May 13, 2008 | 01:55 PM
hondaLovin's Avatar
Default Re: Do the springs/retainers need to be upgraded too? (mc-integra111)
Crower 402's are fairly mild. You can probably get away with stock springs and retainer. I'd double check with Crower to make sure.
Old May 13, 2008 | 02:02 PM
steveteggy92's Avatar
You may as well replace them while you're there, find some in the market-place or on Ebay that are either new or slightly used. Another advantage is, if you get new springs and retainers..you can afford to get cams that will have a little more kick to em.
3gcvcd16
Jan 23, 2008 08:46 PM
BrakeDanceJ
Oct 5, 2007 05:49 PM
slysi92
Sep 12, 2007 12:52 PM
bluedlude
Oct 2, 2006 09:24 AM
FROSTDC2
17
Oct 30, 2005 05:58 AM
