which is better?
Old May 13, 2008 | 07:44 AM
dcforgod's Avatar
Default which is better?
Is it better to rebuild my GS-R head or just put a B16B head on?
Old May 13, 2008 | 07:52 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: which is better? (dcforgod)
I would see if I can sell the GS-R head for the low (just tell them it needs rebuilding)
And buy the B16 head and do work...
Old May 13, 2008 | 07:56 AM
dcforgod's Avatar
yeah, I could do that. But is the B16 stringer than the GSR?
Old May 13, 2008 | 08:07 AM
all-mtr-teg's Avatar
Default Re: (dcforgod)
If you plan on rebuilding the head just keep the GSR one
Old May 13, 2008 | 01:12 PM
SleeperGSR's Avatar
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">If you plan on rebuilding the head just keep the GSR one</TD></TR></TABLE>
X2
they are very similar and if you are rebuilding you can make the gsr better than a stock 16a
Old May 13, 2008 | 01:24 PM
dcforgod's Avatar
what's the difference between the 2?
Old May 13, 2008 | 07:04 PM
dcforgod's Avatar
does anyone know?
Old May 13, 2008 | 07:37 PM
jasoncrashtech's Avatar
the p72 doesn't have a quench pad so the combustion chamber is smaller= better compression.
the p30 head has a better angle of ports ( supposedly ) witch is to be better for flow.
to tell the truth both are really good heads . engine builders are happy with either.
if i was you, i would stick with the p72.
hope i helped
Modified by jasoncrashtech at 6:39 PM 5/14/2008
Old May 13, 2008 | 07:42 PM
http://asia.vtec.net/beystock/honda/civicr/
http://asian_e.tripod.com/Honda_Engine_Specs.htm
Old May 14, 2008 | 05:07 AM
Jimmy's Avatar
Global Moderator
Either are fine.
The B16 has a slightly better flowing intake manifold
integra321
Jul 8, 2006 09:47 PM
drag-ek
Feb 23, 2006 04:41 PM
Hatchorama
31
Jun 20, 2005 03:42 AM
Option
Nov 1, 2004 12:53 PM
stockb16
Apr 26, 2004 12:55 PM
