Moroso oil pan leaking on turbo motor.
I have a turbo Ls/Vtec, and i have the Moroso stock replacement oil pan, with the return bung on it. The problem is that I can't get it to stop leaking. I have tried a new oil pan gasket, and the I tried hondabond on a new gasket , then I went to RTV alone, and now I am stuck.
So you guy know of any trick that would get it to stop leaking.
Did you make sure the two metal washers were removed on your oil pump studs before you put the new oil pan gasket on? The oil pan gasket has two metal washers inside it that you can not see. Chances are you double stacked them causing it to leak.
yeah I've been through all the possible things, I tightened it in the proper sequence, and torque spec, I removed the washers from the old gasket, and I let the RTV cure for about 20 mins before installing then I let it set beofre final torquing it down.
deconstruct
Jun 18, 2004 01:00 PM
