1994 LS steering PROBLEM!@!
Old May 12, 2008 | 10:23 PM
volcomstoned's Avatar
Default 1994 LS steering PROBLEM!@!
ok i have a 1994 integra ls, i took out the power steering.(pumps, lines ect.)
i just replaced my upper A arms with another OEM A arm on both side. bolted everything down correctly but now when i turn the steering wheel doesnt turn back by itself.i have to manually turn it back. could it be the power steering or my car need a new alignment?
Old May 12, 2008 | 10:28 PM
Default Re: 1994 LS steering PROBLEM!@! (volcomstoned)
please help
Old May 12, 2008 | 10:34 PM
choji's Avatar
maybe take it in for an alignment
Old May 12, 2008 | 10:36 PM
Default Re: (choji)
i am going to tomorrow but just wanted to see if anything has the same problem.
Old May 13, 2008 | 01:30 AM
Default Re: (volcomstoned)
help
Old May 13, 2008 | 12:37 PM
wow, no one?
Old May 13, 2008 | 02:47 PM
AlphaQup's Avatar
So your saying, if you're doing a U-turn, you'd have to manually turn it back to go straight again? Otherwise It'd keep doing donuts at the intersection? I think it could be a problem with your A-arms being installed improperly. Double check your work on that. Also what kind of car did those OEM A-arms come off of?
NeverLift
Sep 28, 2008 01:12 AM
volcomstoned
Suspension & Brakes
May 13, 2008 12:38 PM
JDMmovement
May 8, 2007 03:36 PM
