del sol swap question
-95 honda del sol si (sohc vtec)
-swapping in a 96 OBD2 ex d16y8
-i kno the ecu side is plug and play cuz im going to run my obd2 harness into a jumper then into a chipped and tuned p28
-question is what will be different on the drivers side? will i have to add/take away im not sure and the server is still unavailable to search other wise i would
You can also run an obd1 to obd2 conversion harness with a P2P, that's the correct ecu to use for that motor, but a p28 will also work too.
gulftiresinc
Dec 14, 2007 04:36 PM
94delsoltypeR
11
Aug 15, 2007 06:57 AM
