help. d15b2 --> d15b8
Old May 12, 2008 | 08:21 PM
88da3's Avatar
Default help. d15b2 --> d15b8
i have a 91 civic that i just put a d15b8 into. its using the stock d15b2 manifold. everything bolted up fine but it is having trouble starting. it starts and runs rough for literally 2-3 seconds and dies. i triple checked the firing order and connectors and everything checks out. any ideas? im thinking because the b8 is an 8 valve motor and the b2 is a 16 valve, maybe the ecu is dumping too much fuel? help please. im stumped.
Old May 12, 2008 | 08:30 PM
cherroneballs's Avatar
are you running the dx manifold or the 4 injector manifold????
Old May 12, 2008 | 08:36 PM
88da3's Avatar
Default Re: (cherroneballs)
im using the d15b2 manifold w/o injectors....basically i have a b8 block with the b2 manifolds, tranny, ecu, etc. nothing else was changed on the car from stock except for the block.
Old May 12, 2008 | 08:45 PM
sounds like you answered yourown question, putting a 8 valve motor where a 16 valve motor is needed, Don't know about a 8 valve motor but seems logical, sorry not much help but throwing something out there.
wasapyt
Jul 20, 2010 03:37 AM
4ornia
20
Mar 20, 2007 04:00 PM
93egbeau
Jan 26, 2006 01:22 PM
spnbb2
Sep 3, 2004 05:30 AM
