car dieing due to turning on accessories
Ok my car's RPM drops a couple hundred whenever the lights or A/c is switched on. At a complete stop it's fine.
But while driving then hitting the clutch and letting it coast it will die. It doesn't shake like a stall. You don't realize the car dies until you try to hit the gas or steer.
I don't believe it's a coincidence as I can make it die fairly quickly after turing on lights or a/c.
Any ideas guys?
Any ideas guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vthondaboi »</TD></TR><TR><TD CLASS="quote">I can make it die fairly quickly after turing on lights or a/c.
Any ideas guys?</TD></TR></TABLE>
Get the battery and the alternator tested.
Sounds possibly like a short somewhere. Not sure why it wouldn't die at idle, though. I'm curious too because recently my car just died on the freeway; didn't even realize it had until I went to put on some gas and then realized it was dead. Now I can't get it to turn over and my battery is draining. However, I had the battery and alternator tested today and both were fine, but I'm getting some voltage to the negative battery clamp even when it's disconnected from the battery.
meangreenEG
30
Jul 5, 2007 08:56 AM
dmxsoulja3
12
Dec 24, 2004 11:55 AM
7808
12
Jun 6, 2004 02:46 AM
