2000 SI With B16 SIRII Swap
Old May 12, 2008 | 06:01 PM
duneracer69's Avatar
Default 2000 SI With B16 SIRII Swap
I have a quick question will i be able to run the stock ecu with this swap someone told me about a jumper harness i will need to buy to make it work or do i need to have a chipped ecu any help would be great guys this is my first swap
Old May 12, 2008 | 06:05 PM
elektronsi's Avatar
Default Re: 2000 SI With B16 SIRII Swap (duneracer69)
quick question....why would you waste money buying a B16 SIRII when youve already got a B16a2
Old May 12, 2008 | 06:11 PM
Default Re: 2000 SI With B16 SIRII Swap (elektronsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elektronsi &raquo;</TD></TR><TR><TD CLASS="quote">quick question....why would you waste money buying a B16 SIRII when youve already got a B16a2</TD></TR></TABLE>
i guess i should i have said that in the posting the motor is scattered and i already have the SIR motor
Old May 12, 2008 | 06:24 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Swap over the sensors and injectors. Keep your original ECU and wiring harness. Swap over your oil pump and housing and timing belt drive gear and related hardare and brackets for the misfire sensor. Obviously the sensor itself as well.
Easy.
Plug everything in, put the motor in the car and enjoy.
mynameizstitch
Aug 11, 2009 07:40 AM
hastingsr
Nov 12, 2008 06:26 PM
teameco
Nov 14, 2005 05:12 PM
teamexcel
Mar 31, 2004 07:54 PM
