Really need your help with brakes!
Old May 12, 2008 | 05:33 PM
Mikes2000civicsi's Avatar
Default Really need your help with brakes!
Hey guys,
So i hear a rubbing sound from the rear passenger tire as i slow down.i get out and my rota slip is hot as hell after a highway drive of 10 mins.All the other rims are fine.Also the brake pad is more worn then the other side.Could this possibly be a cailper seizing,or another problem,thanks h-t
Old May 12, 2008 | 05:38 PM
elektronsi's Avatar
Default Re: Really need your help with brakes! (Mikes2000civicsi)
e-brake mechanism could be seized, it happened on my buddies 95 gsr
Old May 12, 2008 | 05:41 PM
Default Re: Really need your help with brakes! (elektronsi)
it only looks like the right 1 though..could it still be seized only on that side
Old May 12, 2008 | 06:45 PM
elektronsi's Avatar
yes, its not the actual e-brake inside the car but the mechanism on the right side rear, take off your tire and trace out the e-brake cable check it from where it y's off under the car all the way to the rear brake, then compare it with the drivers side one maybe that will give you an idea if its locked up or not, also while your at it you might as well pull off the caliper and see if thats seized up
bopbop93030
Jul 7, 2008 12:26 AM
Pishpeng
26
Feb 5, 2007 08:09 AM
PreludePhill
May 5, 2006 07:22 AM
sleepystyle
Jan 11, 2006 01:15 PM
xxxmikenicexxx
Mar 15, 2004 06:24 AM
