Really need your help with brakes!
Hey guys,
So i hear a rubbing sound from the rear passenger tire as i slow down.i get out and my rota slip is hot as hell after a highway drive of 10 mins.All the other rims are fine.Also the brake pad is more worn then the other side.Could this possibly be a cailper seizing,or another problem,thanks h-t
Re: Really need your help with brakes! (Mikes2000civicsi)
yes, its not the actual e-brake inside the car but the mechanism on the right side rear, take off your tire and trace out the e-brake cable check it from where it y's off under the car all the way to the rear brake, then compare it with the drivers side one maybe that will give you an idea if its locked up or not, also while your at it you might as well pull off the caliper and see if thats seized up
sleepystyle
01-11-2006 01:15 PM
