Knowing when to up your fuel?
Old Jul 14, 2002 | 03:48 PM
hondacivic4g's Avatar
Default Knowing when to up your fuel?
I have a 89 SI hatch w/ D16A6 in it. I'm adding a D16Y8 intake manifold and a B-series throttle body and a cold air intake.
In the place of the stock intake manifold ,Throttle body and intake.
From what i gather i'm increasing throttle body size by 5mm and not sure how much with the intake manifold or if it's just a better flow.
I was wondering since i'm increasing the incoming air volume, do i need to or can increase the fuel delivery also?
What will make this a benificial upgrade and or is there any other tuning required?
Old Jul 14, 2002 | 06:24 PM
Kamin's Avatar
Default Re: Knowing when to up your fuel? (hondacivic4g)
anytime the engine gets more air the engine needs more fuel.
when you start modifying heavily (intake system, cams, etc) you need to up the fuel
heres my reccomendation
get an adjustable FPR, an a/f meter (the gauge) and go get it tuned.
Old Jul 14, 2002 | 07:48 PM
-TJ's Avatar
-TJ
Default Re: Knowing when to up your fuel? (Teken)
you are not necessarily filling the cylinders any more with those parts. They're not bad parts, but a cam would compliment them well. The above advice is good.
Old Jul 14, 2002 | 10:49 PM
I've decided to go ahead and buy an Air/Fuel meter and an adjustable fuel regulator.
Even if the Air/Fuel meter tells me there is no need for fuel increase, I'll set it to stock flow.
I can still use it at the begining of the year when i swap in my D16Z6 w/ T25 turbo
Then I will deffinately need a fuel increase.
Whats a EGT gauge?( Guessing exhaust gas tempature gauge?)
Thanks for the help
Old Jul 15, 2002 | 01:02 AM
Dutchie's Avatar
Thanks for the help
Yep. You can use these to see how lean/rich you are running. I think you can tell more from these than shitty air/fuel meters (Autometer).
Old Jul 15, 2002 | 09:26 AM
builthatch's Avatar
MiG-21 superfan
one thing to remember is the pyrometer for most egt gauges dictates what happened seconds ago, in an environment where destruction can occure in less than a few seconds.. with fi, tuning, especially on the ragged edge of detonation for max hp, has to be made realtime. this is where a dyno with a motec a/f meter or a egt unit like the one offered by percy's (computech?) is superior. that piece has realtime instantaneous readings with individual pyros in each primary or secondary.
[Modified by builthatch, 1:54 PM 7/15/2002]
Old Jul 15, 2002 | 12:16 PM
Thank you evry one for the information you'll have shared.
I'm looking at either Apexi AFC-S,the Apexi AFC-V or the Motec A/F meter.
Does Apexi have a meter that is a combo of the two (AFC-V + AFC-S)=AFC-V/S ?
When the Swap is done, i would like to have a way to adjust Vtec ingagement also.
So would my best choice be the Apexi AFC-V ?
Also ther are several different brands of adjustable Fuel regulators, does any body recommend a specific one?
Or are they all about the same?
So far i was looking at the B&M Command-Flo FPR w/ pressure gauge.
Thanks again for all the help
Old Jul 16, 2002 | 12:35 PM
ttt
93integra93
Nov 15, 2010 05:41 AM
gmctruck68
Apr 24, 2008 11:56 AM
Pippen_001
Jul 25, 2006 07:45 PM
hondacivic4g
Jul 16, 2002 06:51 AM
