Anyone use hytech replica in EF with B16a and full size radiator?
I'm using hasport mounts and a full-race front crossmember with stock DA dual core full size radiator that's slanted back slightly.
Thanks
Thanks
I wanted to know if the header hits the radiator at all.... Is there going to be a need for a 1/2 radiator?
I have a B18 and a DA radiator and my Hytech replica clears with plenty of room in fact I should be able to install my condensor fan as well!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken »</TD></TR><TR><TD CLASS="quote">I have a B18 and a DA radiator and my Hytech replica clears with plenty of room in fact I should be able to install my condensor fan as well!!!</TD></TR></TABLE>
Which mount kit you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke »</TD></TR><TR><TD CLASS="quote">Anyone else that can verify what mounts they were using when it fit?
Thanks.
They are all so close it wont matter.
Thanks.
</TD></TR></TABLE>They are all so close it wont matter.
I have a crx with hytech knock off, full-race tb, and stock radiator. Everything clears fine. Oh yeah and hasport mounts, but I do need an sir hood cuz I can't shut mine all the way
B18c1, Hasport mounts, Hytech replica, Innovative traction bar, and stock radiator. Clears stock fan too. Heres a pic:
Which mount kit you using? </TD></TR></TABLE>
Innovative
Innovative
I have place racing mounts with a b16 and a koyo 2 core radiator and a place racing traction bar and the stock exhaust manifold is too close for comfort. I would like to know if that same setup would fit a koyo 2 core radiator? does anybody have pictures with one?
Modified by mullet eater at 7:15 PM 5/13/2008
Do you guys think this would fit? It looks like it might from the pics.
I have hasports which should put the engine further back comparatively but my car is in pieces and I put these fans on then suddenly realized I'm not certain it'll fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khmi »</TD></TR><TR><TD CLASS="quote">B18c1, Hasport mounts, Hytech replica, Innovative traction bar, and stock radiator. Clears stock fan too. </TD></TR></TABLE>
I'm assuming all Hytech replica's are the tri-design. What's your ground clearance like? Is your car dropped at all, or are your riding stock height?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stunn’d »</TD></TR><TR><TD CLASS="quote">I doubt that'll clear with the drivers side fan on there</TD></TR></TABLE>
That's what I'm afraid of... oh well... we'll see...
It does fit with no problem. I removed the inlet/outlet for the unused tranny cooler to make for ease of install. It fit without cutting it, but it only had like a 1/16 till it hit. It didn't come with the bolts that hold the two pieces together though.
It didn't come with the flange for the extention pipe either.... I figured it would have.
Other than that it looks good. Can't wait to dyno it.
Modified by brokenojoke at 2:41 AM 5/15/2008
SimbaDogg
Jan 12, 2004 10:55 AM
