89 CRX Si Drivers side door lock
Buy a used drivers doorhanle or a lock cylinders on rockauto and take it to a locksmith. They can re-key it to fit your original key.
But to answer your question, the part# is 72146-SH3-023 and is discontinued.
Pretty sure any 88-91 Civic lock cylinder will work, but you may want to check me on that. I had the same thing happen to me...the good news is that the guy probably didn't damage the cylinder or tumblers...just the little sheet-metal door / flap that closes when you pull the key out. If you have a local junk yard, go pull a lock cylinder from an 88-91 Civic and you can pull the wafer tumblers out of your damaged cylinder and put them in the new one. The wafers each have a number on them (1 through 4 I think?)...just make sure you put them in the correct order. when you swap them over.
and you can fix this yourself
its really easy no need to pay anyone anything to fix it
if you want to see pictures on how to make your repair go to page 5 of my build thread
Marcos new work car 90 sedan
there youll see how to remove the lock and take it apart and fix it
good luck
advancexz
Honda Civic (2006 - 2015)
Feb 4, 2012 04:18 PM
djdc2
Mar 7, 2007 04:17 PM
