89 CRX Si Drivers side door lock
Anyone know the replacement part# for this or if other years of honda locks will work? Someone really messed mine up with a screwdriver.
Thanks.
Thanks.
Re: 89 CRX Si Drivers side door lock
Pretty sure any 88-91 Civic lock cylinder will work, but you may want to check me on that. I had the same thing happen to me...the good news is that the guy probably didn't damage the cylinder or tumblers...just the little sheet-metal door / flap that closes when you pull the key out. If you have a local junk yard, go pull a lock cylinder from an 88-91 Civic and you can pull the wafer tumblers out of your damaged cylinder and put them in the new one. The wafers each have a number on them (1 through 4 I think?)...just make sure you put them in the correct order. when you swap them over.
and you can fix this yourself
its really easy no need to pay anyone anything to fix it
if you want to see pictures on how to make your repair go to page 5 of my build thread
Marcos new work car 90 sedan
there youll see how to remove the lock and take it apart and fix it
good luck
advancexz
Honda Civic (2006 - 2015)
02-04-2012 04:18 PM
djdc2
03-07-2007 04:17 PM
