95 Integra GSR.. Spitting Oil?
Old May 12, 2008 | 11:02 AM
Left_Sock's Avatar
Default 95 Integra GSR.. Spitting Oil?
Hey everyone,
I just recently bought a 95 Integra GSR and I noticed oil in little specs all over the bumper and the back of the car around the exhaust. Does anyone know why it does this?
Thanks is advance
Old May 12, 2008 | 12:35 PM
goota's Avatar
you burn oil, welcome to vtec world.
Since we have motors which rev really high and switch cam profiles during vtec, our valve seals wear, and we burn oil.
thats the most common reason, there could be others though.
Old May 12, 2008 | 01:24 PM
DougGsrHatch's Avatar
Default Re: 95 Integra GSR.. Spitting Oil? (Left_Sock)
possible piston rings.. same problem i had here and i bought the CTR conversion and havent seen it since..
Old May 12, 2008 | 01:36 PM
super jdm yo's Avatar
Default Re: 95 Integra GSR.. Spitting Oil? (DougGsrHatch)
wouldn't burning oil just cause smoke, i had one motor where the rings went out and that one just burned a whole lot of white smoke out the muffler. then i worked on a motor with bad valves and thats when your car sounds like a subaru. i've never heard of oil actually coming out of the muffler.
Old May 12, 2008 | 02:12 PM
DC2andED6's Avatar
OMG!! Dude! I have the same problem. When I first seen it I freaked out, but it's been about a year now, and she's still running fine, so i just try to forget about it...lol
Old May 12, 2008 | 03:02 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Left_Sock &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone,
Thanks is advance</TD></TR></TABLE>
My civic did this. My integra doesn't. A couple things you might want to look at or think of:
- How much oil does your car burn?
- Is your head gasket bad? Oil in the coolant. Coolant in the oil
- How do your spark plugs look? Is one of them glossy black?
Aside from preventative maintenance, I would say that there isn't anything, aside from taking off the piping from your car and pushing a rag through to clean it out that you can do to get rid of this. I don't think it's oil per-say. I think it's a mix of water and all the exaust stuff that sticks to the piping. Then when you start the car after a while it spits out the condensation from the night.
I think this is also more likely to happen with aftermarket piping because it offers less restriction for condensation to work it's way through the system.
Old May 12, 2008 | 03:06 PM
FuNkDrSpOt's Avatar
Default Re: 95 Integra GSR.. Spitting Oil? (super jdm yo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super jdm yo &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't burning oil just cause smoke, i had one motor where the rings went out and that one just burned a whole lot of white smoke out the muffler. then i worked on a motor with bad valves and thats when your car sounds like a subaru. i've never heard of oil actually coming out of the muffler. </TD></TR></TABLE>
That would be burning oil but oil can actually be left unused and still pass through the system. IE, some of it escaped without actually igniting.
Old May 12, 2008 | 04:07 PM
Left_Sock's Avatar
Default Re: 95 Integra GSR.. Spitting Oil? (FuNkDrSpOt)
Thanks guys, I notice it mostly when it rev's up like when you give it a shot of gas, a little cloud ( nothign major) comes out and by then i get home theres little bits of black liquid all over the rear bumper. Doesnt seem to be causing any problems just curious
Old May 12, 2008 | 04:12 PM
Left_Sock's Avatar
And it burned about 1 quart of oil for around 650 km's
Old May 12, 2008 | 06:02 PM
SIC_jdm_da9's Avatar
my car does the same thing and i try to not let it get to me but w/e yeahh it means your just burning oil. this is on my LS but yeahh
Old May 12, 2008 | 11:56 PM
goota's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Left_Sock &raquo;</TD></TR><TR><TD CLASS="quote">And it burned about 1 quart of oil for around 650 km's </TD></TR></TABLE>
Thats a little high, you might want to look into doing some refreshment on your engine.
Old May 13, 2008 | 07:05 AM
FuNkDrSpOt's Avatar
Default Re: 95 Integra GSR.. Spitting Oil? (goota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goota &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a little high, you might want to look into doing some refreshment on your engine.</TD></TR></TABLE>
That's HELLA high. You're burning more than a liter every 400 miles.
Way too high, your headgasket or rings are gone. Plan some time in the near future to rebuild the engine.
gotrust
Oct 28, 2010 08:26 PM
azzure180
Nov 24, 2009 10:35 AM
todbld
Oct 20, 2005 11:50 AM
Mar_DC2
Oct 2, 2004 02:07 AM
Blazin Si
Aug 27, 2003 06:45 AM
