rear disc conversion question
Old May 12, 2008 | 06:29 AM
98GSR-Turbo's Avatar
Default rear disc conversion question
will the 90-93 integra rear disc brake system fit on a eg or not? if not what vehicle do i need the get the conversion parts off of?
Old May 12, 2008 | 06:49 AM
Andres-eh2's Avatar
yes it will fit. Im pretty sure you can use the trailing arm but u just need to swap the UCA and Toe Link adjuster to the civic one. u also need 92-95 civic ebrake cables and a 4040 prop valve. When i did my rear disk i swapped the hubs by removing the 4 TORX bolts on the back then swapped them all back
Old May 12, 2008 | 07:53 AM
slacks's Avatar
Default Re: (Andres-eh2)
i actually used integra cables with my swap even though mine were from a 94+ integra and was told not up upgrade the prop valve since the front brakes are your primary stopping source anyway
Old May 12, 2008 | 10:13 AM
92VXeg's Avatar
Default Re: (slacks)
stops fine with stock prop valve though. my 40/40 prop valve leaked so i used stock on on my rear disc converson. Only difference i think it with the stock prop valve is that if you lock it down the rear will be just like pulling the e-brake?
Old May 12, 2008 | 11:06 AM
riceburnerryan's Avatar
when i did my rear disc conversion i used the DC integra brake cables, but i didnt get the 40/40 valve... i did, however, get the brake booster and master cylinder. i thought that my brakes felt "stronger" than before i had the brake booster and master cylinder *like the brake pedal didnt feel mushy*
Old May 12, 2008 | 11:17 AM
greenwallseries's Avatar
wouldn't parts from a del sol or a 92-95 si work better?
Old May 12, 2008 | 11:21 AM
slacks's Avatar
Default Re: (greenwallseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenwallseries &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't parts from a del sol or a 92-95 si work better?</TD></TR></TABLE>
it's all the same stuff
Old May 16, 2008 | 01:34 PM
so the 90-93 teg rear brakes will work on an eg?
Old May 16, 2008 | 02:03 PM
slacks's Avatar
Default Re: (98GSR-Turbo)
yeah you'll be good
just reuse your lca's and camber piece (that's a pain to take off anyway)
hhardell
Suspension & Brakes
Feb 13, 2013 07:13 AM
JDM EJ2
20
Oct 9, 2008 10:00 PM
Ebrake650
Jan 14, 2008 12:18 PM
xxmikexx206
Jul 5, 2007 04:01 PM
