1999 Integra GSR blk/blk, built head, cams, lowered, CLEAN-GENEVA, IL
PRICE LOWERED*********AGAIN
Hey everyone. i have a 1999 Integra GSR. i purchased this car just about a year ago. i purchased it from a local Honda Dealer. it had 112,xxx on it at the time. i purchased this car completely stock. one owner from back in 1999. every modification done to this car has been done since i have owned it. i am pretty picky on how things turn out and refuse to let any corners get cut. i have had quite a bit of work done to this car, but i have just lost interest in modifying cars and wanting to put anymore money in this car. Im actually looking for an automatic 4 door car- Preferably a 98-01 audi a4. that is probably one of the only things that i will trade for. I have well over 12,000 into this car including the cost of the car. but I'm ready to move on.
Asking price is $6500 obo. and im very very open to offers now. please let me know. i want it gone asap
Thanks for looking
On to the Specs……
SPECS:
1999 Acura Integra GSR (DC2)
Nighthawk Black / Black Leather
130,xxx miles (original)
Car was originally purchased and owned in chicago. The original owner lived in Naperville, IL, and i live about 20 minutes away in Geneva, IL
SPECIFICATIONS
Engine:
B18C1 (GSR) block, all stock, original, 130,xxx miles on it. Compression tested 185 on all four
B16A2 Head:
-Skunk2 Flat Valves
-Skunk2 Dual Valve Springs
-Skunk2 Titanium Retainers
-Skunk2 Stage 2 Street Cams
AEM Cam Gears (Red/Silver)
Integra Type R Intake Manifold
Profab Intake Gasket
B&M Fuel Pressure Regualtor
Blox Fuel Pressure Guage
ARP Headstuds
Buddyclub 2-Layer Head Gasket
-Currently Im running the stock ITR intake. this car has way more potential especially with the cams and built head with an aftermarket intake.
Head was built by Factory 5 Motoring (Profunction)
All the maintenance and head install was done by One6 Motorsports at 128,874 miles
Drivetrain:
Blox Short throw shifter
ACT Street Clutch W/extreme Pressure plate
ITR Flywheel
-Clutch and Flywheel Installed by One6 Motorsports at 128,874 (clutch is used appx. 5,000mi)
Interior:
OEM ITR shift boot
Skunk2 weighted shift ****
Braking:
Powerslot Rotors F&R
Hawk HPS Pads F&R
-Installed at 122,xxx
Wheels/Tires:
205/50/15 Khumo Ecsta ASX
Exterior:
Mod Express 8000k HID Kit
Suspension:
K-Sport Coilovers 36-way adjustable
PIC Standard Lower Control Arms
Exhaust:
Omni 2.5” Test Pipe (Not installed, but included)
DC Sports 2.5” Catback
Maintenance:
Radiator (Installed at 122,xxx)
New Window & regulator
New Antenna Mast (not installed, but included)
New OEM water pump —@128,874
New OEM Timing belt —@128,874
New OEM Accy belts —@128,874
New OEM Distributor Cap —@128,874
New OEM Distributor Rotor—@128,874
New OEM Plug Wires —@128,874
New OEM Vtec Solenoid Gasket —@128,874
New OEM Radiator Hoses —@128,874
New OEM Fuel Filter —@128,874
New OEM Pilot & Throw-Out Bearing —@128,874
NEW OEM Trans Fluid Changed/ Clutch Fluid changed —@128,874
New OEM Clutch Master Cylinder —@128,874
New NGK Spark Plugs —@128,874
New OEM thermostat @125,227
Car will be running on a chipped p28 on chrome. VTEC engage at 4500, redline 8600
ECU will be done in about a week.
I have a lot of work and all of the maintenance done with this car. It doesnt burn a drop of oil. oil changed every 2,500. This car has the potential to be a very low 14 second or even high 13 second car. After all the work i have had done the car gets somewhere between 25-30 MPG's. I have removed the rear spoiler but still have it and it would be included with the car along with a bunch of miscellaneous parts. in some of the pictures, there is a front lip. it is not included with the car, i do not have it anymore. Interior is flawless.
NOTE: i need to take pictures of the engine bay. they will be up in a couple days.
Flaws:
Minor Rust on passenger side rear quarter
Rust on rear hatch.
Stock GSR Blades need to be refinished they are pitted from the chicago winters.
****Reverse is very hard to get into. i had it looked at. and the reverse synchro is bad
Pictures.....
Modified by serr38 at 3:19 PM 5/12/2008
Modified by serr38 at 2:37 PM 5/18/2008
Modified by serr38 at 2:38 PM 5/18/2008
Modified by serr38 at 8:31 PM 5/20/2008
Modified by serr38 at 10:49 AM 5/22/2008
Modified by serr38 at 12:46 AM 5/24/2008
Thanks for looking
On to the Specs……
SPECS:
SPECIFICATIONS
Engine:
B16A2 Head:
-Skunk2 Flat Valves
ARP Headstuds
Drivetrain:
ITR Flywheel
Interior:
OEM ITR shift boot
Braking:
Hawk HPS Pads F&R
Wheels/Tires:
Exterior:
Suspension:
Exhaust:
Maintenance:
Flaws:
Rust on rear hatch.
Pictures.....
It's really nice to see someone clean a car well before they post pictures. Wish y ou were closer. i'm looking for a nice DC!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenjyJ »</TD></TR><TR><TD CLASS="quote">this car is MINTTTTTT.
wish i had the cash, i could offer you $5000 and an STD... </TD></TR></TABLE>
the std is too nice. we'd need the teg and 5000
