Progress of my YZF600 project
Old May 11, 2008 | 05:42 PM
Jasper_db1's Avatar
Default Progress of my YZF600 project
I know a lot of you guys enjoy working on and building older bikes. This YZF is my first bike and I used it as a commuter for a couple of years until it lost 2nd gear. At that point, I pulled the engine and performed a complete rebuild. Not being able to leave **** alone, I ended up rebuilding the entire bike. Here's what I posted on a YZF forum:
I finished building the engine complete with the Falicon adjustable cam gears and a Factory Pro ignition advance kit. The engine's been reinstalled into the frame. I've been busy painting and finishing it up. Here's a teaser of how the bike looks now:
I fixed all the dents in the tank which took a total of 12 hours worth of work. This is my first attempt at bodywork and I learned a lot. The tank is painted with 2 coats of Duplicolor primer, 1 coat Duplicolor primer sealer, 3 coats of Duplicolor "gloss" white. I have not color sanded the tank as I am not pleased with the rattle can paint at all.
The last things I need to do are:
= Finish prepping the front fairing and then I'll be able to paint the whole thing. I got frustrated with the cheap quality of paints that come out of the spray cans so I bought a couple of HVLP paint guns and some real polyurethane paint and clear. I can't wait to try this stuff out!
= I don't know if you all noticed but there's a 2005 R6 radiator under the fairing. This unit is larger than the stock one and its curved. The only problem is that I need to make some pipes for the radiator hoses. I'm mocking that up now.
= Install the new Hella 90mm head lights which will require a custom bracket.
= Build a custom bracket for the Aprilia tail light/signals/license plate
= Build a custom mid-pipe from the header to a spare Moriwaki muffler.
Once all that stuff is sorted out, I'll pull the engine out again and powder coat the frame.
:cheers
Old May 11, 2008 | 07:41 PM
Sliced Beard's Avatar
Default Re: Progress of my YZF600 project (Jasper_db1)
you know something man, the more I look at that bike the more I thik it would look great if you "kinda" streetfighter'ed it out. Since you already have a full fairing bike, why not have another one that is more of an in town thrasher/slasher with some pep?
Jus my input. I know you like the nestalgia of it being your first bike, but why not go in a alternate route with it and give the old a new edge?
Old May 11, 2008 | 09:14 PM
Jasper_db1's Avatar
Default Re: Progress of my YZF600 project (DirtySol)
I've seen a couple of attempts at SF'n this chassis and it never looks right.
Old May 11, 2008 | 09:41 PM
marmaladedad's Avatar
The rattle can job looks pretty good...! What part of it don't you like?
Old May 11, 2008 | 11:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">I've seen a couple of attempts at SF'n this chassis and it never looks right.</TD></TR></TABLE>
that chassis would NEED a bikini fairing to look good as a SF. But it could be done rather easily and it could look VERY good. The radiator and top/front of the engine needs to be disguised a bit tho. They are not very pleasing to the eye.
Old May 12, 2008 | 07:24 AM
Jasper_db1's Avatar
Default Re: (marmaladedad)
The paint that comes out of the rattle cans is really thin and doesn't take much for it to scratch. On the RC51's tail section, I sprayed 3 coats of paint and then wet sanded with 1000 and 1500. By the time I got it smooth, I could see the primer below the paint! All the time spent prepping and finishing was wasted by inferior materials.
Old May 12, 2008 | 07:35 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (Jasper_db1)
powdercoat the frame black, take fairings off, put some usd's on it, and a set of renthals and u could have a sick fighter.
Old May 12, 2008 | 07:53 AM
MSchu's Avatar
My Name is Nobody
Gold wheels
Old May 12, 2008 | 08:38 AM
Jasper_db1's Avatar
Default Re: (MSchu)
Don't tempt me
Old May 12, 2008 | 06:21 PM
civic08's Avatar
Default Re: (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">Gold wheels </TD></TR></TABLE>
GOLD WHEELZ!
Mag00n
Honda Motorcycles
Feb 22, 2007 10:16 PM
Jasper_db1
Honda Motorcycles
31
Nov 25, 2006 12:06 AM
hi mom
Honda Motorcycles
22
Sep 11, 2006 06:47 PM
