Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
14 x 5 wheels and tires
Old May 11, 2008 | 04:35 PM
dfoxengr's Avatar
Default 14 x 5 wheels and tires
I cant find any aftermarket wheels that are 14 x 5. Can anyone point me in the right direction. regardless of cost and design(1/3 piece)
Also, 225's will work on 14 x 5's right? I believe they do, but I needed a second opinion.
thank you..
Old May 11, 2008 | 05:12 PM
verticle's Avatar
Default Re: 14 x 5 wheels and tires (dfoxengr)
it might just be me, but 225's seem too big for a 5" wide wheel.
any reason for only wanting a 5" wide wheel?
Old May 11, 2008 | 06:34 PM
dfoxengr's Avatar
Default Re: 14 x 5 wheels and tires (verticle)
stock class
Old May 11, 2008 | 06:50 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">stock class</TD></TR></TABLE>
What's your bolt pattern and offset range? Should be +/- 5mm but I don't know what yours is stock.
225/50 should be fine.
Work Equip 14x5 in +23 and +13
http://www.vividracing.com/cat....html
SSR Type C in +38, +45
http://www.neweraparts.com/Def...D=520
Old May 11, 2008 | 07:07 PM
dfoxengr's Avatar
Default Re: 14 x 5 wheels and tires (Chris F)
thank you very much.
crx wheels are 14 x 5 with 38mm BS I believe.
Ill check those out.
seems as thats the only place on the net that carries those SSR wheels, odd....
Modified by dfoxengr at 11:15 PM 5/11/2008
Old May 11, 2008 | 07:18 PM
civexspeedy's Avatar
I remember seeing a chart that had a list of wheel sizes. IIRC, it said the widest you can put on a 5.5 was a 205 series. im not 100% sure but that sounds about right. i cant find the chart now but ill see if i can pull it up later.
Old May 11, 2008 | 07:24 PM
dfoxengr's Avatar
Default Re: 14 x 5 wheels and tires (civexspeedy)
sure, thank you.
I think people on the scca forums were saying they put bigger sizes on regardless of what is recommended though.
Old May 11, 2008 | 07:43 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">sure, thank you.
I think people on the scca forums were saying they put bigger sizes on regardless of what is recommended though.</TD></TR></TABLE>
definitely, for autocross, fit whatever fits in the wheel well The guys at Discount Tire will probably look at you sideways when you try to get them mounted, but they'll usually do it. If not find a racer-friendly place.
Old May 12, 2008 | 07:47 AM
Seminole Civic's Avatar
I purchased a set of 205/55-R14 Avon Tech R's earlier this year and they were listed for rims 5.5-7". I've heard some of the R-compounds are wider than street tires of the same size callout, and these look as wide as a street 225 to me.
Don't know what year or model you have, but many had 14x5.5 size rims as stand alone optional equipment. If this was the case for your model, I think the rules would allow you to go with a 5.5" width.
Old May 12, 2008 | 08:01 AM
dfoxengr's Avatar
Default Re: 14 x 5 wheels and tires (Seminole Civic)
crx si have that option?
Immortal-Prelude
Dec 7, 2007 03:20 PM
The Phil
Honda S2000
Sep 12, 2006 08:08 AM
ralli
Mar 14, 2006 02:50 PM
spoonlongblock
20
Feb 6, 2006 04:20 AM
