water pump, 2 choices help me out.... Can I do this to remove it?
Old May 11, 2008 | 04:03 PM
JUN.'s Avatar
Default water pump, 2 choices help me out.... Can I do this to remove it?
Ok so I have a civic 91 hb with a 1st gent b16 swap. I believe that the water pump is leaking because there is water dripping between the timing belt plastic cover and the block.
I though of 2 choices since I dont have a compressor/ impact gun.
1st choice: I will ask a friend to remove the crank pulley using his impact gun, so I can remove the lower timing belt cover in his home and after that, he will tight the pulley back. Then I will go home and replace the water pump... After the replacement, I will go and visit him again so I can install the lower plastic cover again.
2nd choice. Make him loose the crank pulley bolt and then tight it a little bit. I will drive home slowly so the bolt doesnt tight and remove it with a breaker bar (i guess it will be easy to remove).
Old May 11, 2008 | 04:22 PM
mhorton's Avatar
Default Re: water pump, 2 choices help me out.... Can I do this to remove it? (JUN.)
I've never had any luck with an impact wrench, so I suggest 3) put a very long pipe over your breaker bar and break it loose that way. I had a terrible time with mine, tried impact wrench, penetrating oil, torch, ext, and finally got it off with little trouble using a 2.5" diameter 4' long pipe of PVC plastic of all things, over my normal ratchet. It was my last resort because I thought the plastic would crack.
but of your options, 1 sounds better. They seem to seize up again just from tightening without even running, and what if it happened to work loose on the way?
Old May 11, 2008 | 04:31 PM
green91's Avatar
Dont drive it with the crank pulley loose under any circumstances! I really recommend buying a crank tool or a chain wrench and just doing it all at one time.
Old May 11, 2008 | 05:12 PM
zrickety's Avatar
Default Re: (green91)
use the breaker bar and a long pipe...it's WAY more effective than any impact gun i've ever used. just make sure you can keep the flywheel from moving
Old May 11, 2008 | 06:05 PM
DAP91Si's Avatar
I did option #2 when I had to replace my water pump. The only other problem I had was working the pulley off.
Old May 11, 2008 | 07:47 PM
Hamstr323's Avatar
Default Re: water pump, 2 choices help me out.... Can I do this to remove it? (DAP91Si)
I use an elec impact to do mine but if by hand try this
http://cgi.ebay.com/ebaymotors...wItem
Old May 12, 2008 | 05:53 AM
JUN.'s Avatar
Default Re: water pump, 2 choices help me out.... Can I do this to remove it? (Hamstr323)
with an impact gun it will go out so easy......
Old May 12, 2008 | 10:54 AM
JUN.'s Avatar
well we tried today with the impact gun and it didnt work!
Then we had to remove the starter, lock the flywheel with a prybar and then we used a breaker bar and a long *** pipe and it came off easy....
MADE-IN-BOISE
Aug 8, 2011 10:06 PM
Safebet
Nov 25, 2010 10:33 AM
luggss
Jun 21, 2010 05:13 PM
kixcrx
Jan 27, 2008 08:45 PM
jaymar88
Mar 9, 2003 02:34 AM
