85x89 Dyno numbers and times
Old May 11, 2008 | 03:20 PM
Teamdiesel's Avatar
Default 85x89 Dyno numbers and times
Just about two months ago, I was unable to change my own fuel filter, but then I got ahold of a pdf file of the B18C5 helms manual. Since then I have rebuilt my complete engine with hard work, sweat, and tears. I used some CP 12:1 cr pistons, only to encounter a fuel starvation problem and thus ring and skirt failure. I have since upgraded to a Walbro 255lph fuel pump along with some 11:1 Wiseco pistons (that is right, lower compression) and there was no turning back from there. Here are the resluts of the Wiseco piston and CP piston change (along with fuel pump). The CP graph is red and the wiseco graph is blue.
Old May 11, 2008 | 03:21 PM
Teamdiesel's Avatar
The car ran 13.5 @ 107 mph with a 2.31 60ft on STREET TIRES!
Old May 11, 2008 | 03:36 PM
b19coupe's Avatar
Default Re: 85x89 Dyno numbers and times (Teamdiesel)
Not bad-you want ~13:1 A/F though. Running it at 14:1 could cause engine failure in the long term.
Old May 11, 2008 | 04:39 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: 85x89 Dyno numbers and times (b19coupe)
If the 1st A/F is the way your engined is tuned then get that A/F closer to 13.1.
I agree with B19coupe.
BTW, nice job. You learn very quickly.
Old May 11, 2008 | 06:25 PM
Teamdiesel's Avatar
Thanks . The graphs above were not the final tune anyway. On the final tune I got a flat 13.5 A/F and made 219/160. The ignition and cam gears were untouched.
Old May 12, 2008 | 05:46 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teamdiesel &raquo;</TD></TR><TR><TD CLASS="quote">Here are the resluts of the Wiseco piston and CP piston change</TD></TR></TABLE>
i know our cars can be bitches but thats a little hurtful
Old May 12, 2008 | 07:19 AM
Teamdiesel's Avatar
here are some vids of saturday night. I am the civic hb without the right headlight.
http://www.youtube.com/watch?v=5tcre6y5MPU
http://www.youtube.com/watch?v=7i7VxHlEsl8
http://www.youtube.com/watch?v=6mSwvFrLTAI
milanoteggy
37
May 8, 2013 04:22 PM
94turboeg
Nov 5, 2007 05:23 PM
JDM_Risa
Mar 15, 2004 04:40 AM
GSR_Dude
Sep 26, 2001 12:38 PM
