i think i have a bad IAC???
Old May 11, 2008 | 12:01 PM
T9U4ReBgO's Avatar
Default i think i have a bad IAC???
my car is throwing a IAC code and idles crazy..the light only comes on when its warm then starts running like ****...it runs fine when the light isnt on and when its cold...how can i check to see if it is bad or should i try to bleed the coolant first.. i have a B16A...any input will help thanks
Old May 11, 2008 | 01:42 PM
itslogz's Avatar
Default Re: i think i have a bad IAC??? (T9U4ReBgO)
If the light is on, then its probably bad.
Unplug the IACV when the car is idling bad, if it stops idling bad then you've found you're problem.
Bleed the coolant first though. If you're throwing code 14 for IACV then its most likely shot then.
Old May 11, 2008 | 03:06 PM
slowcivic2k's Avatar
If you damaged the harness or connector, check it. If not, still check it. Then replace the valve, faulty internal coil.
Most likely bad wiring.
autodriver
Honda CR-V & Element
Feb 11, 2012 11:50 AM
team 15
Apr 21, 2008 05:49 PM
hondaZvic
Sep 8, 2007 09:14 AM
done
Nov 23, 2002 11:03 AM
vti-R
Sep 25, 2001 08:00 AM
