Drag helps
Hi guys i need some help for my eg drag project... Turbo mainfold ecu transmission fuel pumps.. i need suggestion for buying the correct item onlyone time i have some ideas but every suggestion is welcome
tks
tks
RC Autoworks Log manifold, 3 inch downpipe, 3 inch thermal cat-back exhaust from honda-tech in the forced induction page in the sponsor section here. walbro 255lph fuel pump with an AEM fuel rail, fuel pressure regular and gauge, stage 3 clutch from lsdmotorsports, short shifter from Skunk2, 1000CC injectors, oh screw this...
I don't even know what motor/tranny/setup you have or want. lol
Many tks.
A search into the web yesterday gives to me this:
Turbo from garret t04 or similar
Manifold from pfabrications
crankshaft, rods from eagle
pistons from je (cams from skunk2 ?)
methanol from snow performance
oil pan from moroso.
For the fuel pump maybe i'll be able to find the superbike ducati pump from magneti marelli
that works at 30 bars should be about 400 psi
Wheels from weld racing 15 x 9 inch
I have a eg 1992 civic with b16a2 engine and my target should be 500hp.
i want to install the integra shifter with a lsd differential
For the ecu now i shipped the original one to my tuner in swiss to weld in it a hondata module, but we want to buy one from autronic or one programmable
Now i'm going to check your links
tks tks tks
tks tks tks
I RUN AUTRONIC ON MY 92 VX AND THING IS ANIMO.......BUTt 500 shouldnt b that bad to accomplish now days with all the different parts and with everyone going k, B series getting way cheapper. But just research everything before u buy.....GL
TurboR1391
Aug 30, 2001 09:06 AM
