Taking out A/C Compressor?
Old Jul 14, 2002 | 12:56 PM
FourthGenHatch's Avatar
Default Taking out A/C Compressor?
The Compressor is the huge *** metal thing right? I heard you can save a lot of weight by taking it out. Does it just unbolt or do I have to do a lot of crap to get it out?
Old Jul 14, 2002 | 07:14 PM
Default Re: Taking out A/C Compressor? (FourthGenHatch)
ttt
Old Jul 14, 2002 | 09:19 PM
dingusjt's Avatar
your a/c compressor is located on the bottom of the driver side of the block facing you, looking down it is to the right of your header and its weighs a good 20 pounds. Of course if you take out the compressor you wont have an A/C, if you are really planning on doing this, open up the valves on the A/C lines near the passenger side firewall. This stuff is Freon in 88-91 and under a lot of pressure so stay away so you don't get it on you are inhale. Keep in mind that Freon is toxic and there is a huge fine for letting it into the atmosphere. Once all the pressure is out you can detach the hoses and remove your A/C compressor.
Honestly i dont think it would be worth it unless you have no desire for A/C, i know that Freon costs about 70 buck a lb and i am assuming it would be expensive to refill your A/C system so if you take out the compressor you might as well remove all a/c lines, ac condensor, and evaporator. be careful
Old Jul 14, 2002 | 09:32 PM
racerxadam's Avatar
if you really want to ditch the a/c have a shop evacuate the system. You can really injure yourself by venting the freon. If you were to get it in your eye it could freeze your your eyeball or some extremity and it damages the ozone like crazy
Old Jul 15, 2002 | 10:15 AM
Default Re: Taking out A/C Compressor? (racerxadam)
My A/C blows hot air so does it even have Freon in it?
Old Jul 15, 2002 | 12:28 PM
Ham'ed Hatch
Guest
Posts: n/a
DON'T release it into the atmosphere!!!
think of our kids man!!!
Old Jul 15, 2002 | 12:52 PM
bryant's Avatar
It probley just needs a racharge.
Old Jul 15, 2002 | 01:30 PM
Steve91's Avatar
When you remove the A/C, you need to remove the compressor, condensor and fan, the dryer, all the lines, and the evaporator (this peice is in the car). It saves exactly 42lbs of weight.
Old Jul 15, 2002 | 06:48 PM
Default Re: Taking out A/C Compressor? (Steve91)
I NEED to remove it all? What happens if I don't remove it all? That seems like a lot of work for only 42lbs. I thought the compressor weighed a lot more than that.
Old Jul 15, 2002 | 07:14 PM
dingusjt's Avatar
the compressor is probably one of the heavier pieces, basically if you remove one piece then non of it works, so you might as well take it all out.
Old Jul 15, 2002 | 07:33 PM
Default Re: Taking out A/C Compressor? (dingusjt)
Could I save 40lbs by taking out the center console and the door panels?
See I don't normally drive around like that, but I would like to know what I can do to get below 2000lbs in case I race it or something.
baybay
Aug 26, 2018 02:39 PM
75aces
Mar 4, 2011 03:10 PM
1 Civic I
Jul 26, 2010 06:18 AM
GSR936
25
May 14, 2010 07:47 AM
M@
Mar 31, 2007 10:14 AM
