Jackson racing supercharger compression ratio?
Old May 10, 2008 | 08:34 PM
ITRiWISH's Avatar
Default Jackson racing supercharger compression ratio?
What's the max compression ratio you can run with a jackson racing supercharger?
Old May 10, 2008 | 08:50 PM
Garage 808 Hatch's Avatar
idk about max, but we did an 11.5:1 LS vtec, with an LHT cooled JRSC. ran great
Old May 10, 2008 | 09:40 PM
ITRiWISH's Avatar
Default Re: (Garage 808 Hatch)
really, so you can run it pretty high without damaging the motor unlike turbo's?
Old May 11, 2008 | 09:57 AM
blwn95civic's Avatar
Default Re: (ITRiWISH)
you can run turbo setups on high compression too... it just leaves alot less room for error
Old May 11, 2008 | 11:53 AM
requires good tuning
Old May 11, 2008 | 03:20 PM
ITRiWISH's Avatar
Well I'm build LS/VTEC using JE pistons, 11.7:1 and have pondered the idea of using a jackson racing supercharger. but then if i do use a supercharger what cams do i use? do I use turbo cams?
gsr's or itr's work well
Old May 11, 2008 | 03:23 PM
ITRiWISH's Avatar
really? still put down a lot of power? I just want it to break 250 hp mark
Old May 11, 2008 | 03:48 PM
Schister66's Avatar
Man U FTW
Theoretically you can run as high of a static compression as you like if you have the proper fuel. I wouldnt really worry about the 11.7:1 as long as you do one of two things. One, get an aftercooler for the JRSC or Two, dont plan to run a lot of boost. The problem with the JRSC is that your IATs tend to be rather high on higher boost...without the aftercooler and with the higher compression, you'll have to set your goals low or face detonation.
Old May 11, 2008 | 04:07 PM
ITRiWISH's Avatar
Does anyone make an aftercooler for JRSC?
Old May 11, 2008 | 05:20 PM
LHT welds in cores into JRSC manis
Old May 11, 2008 | 07:36 PM
ITRiWISH's Avatar
Okay, I'll have to check it out.
92integraVTECgsr
Nov 22, 2008 05:53 PM
92integraVTECgsr
Jul 19, 2008 11:51 PM
Speed Infliction
Apr 23, 2006 03:13 PM
crxgsr91
Oct 28, 2004 07:49 AM
untitled
Jan 6, 2004 07:48 PM
