Just drove my ITR for the first time in 15 months...
now I rember why I loved that car so much. Couple questions...
1) When does VTEC kick in for USDM ITRs....isn't it around 5,400 RPMs? I am now running a JDM ECU (I think it is a 96 spec) and it seems like VTEC engages around 6-6,200 RPMs. I wasn't sure if the JDM ECU had a higher VTEC crossover or if my tach is out of calibration?
2) I know there are some minor differences between the USDM engine and a JDM engine...the USDM has more sensors if I remember correctly. Does the JDM engine has the oil pressure sensor? Surely it does, but when my car goes through the self check after turning the ignition, the oil light does not come on. I already checked the bulb, but before I check the switch I wanted to make sure it wasn't due to the JDM ECU.
She is running as good as ever...pretty much everything has been replaced so it feels new to me
Road trip time...gotta make up for all the miles we missed last year!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenCRX »</TD></TR><TR><TD CLASS="quote">Thanks!
1) Is 6,000-6,200 normal for a 96 spec ITR?
2) Time to get my multi-meter out</TD></TR></TABLE>
No, cuz my 96 spec in my old hatch was 5400-5500.
Ouch....so either I don't have a real ITR ECU (which I doubt because I bought it off a reputible Honda-Challenge ITR racer) or my tach is off. Where should the rev limiter be on a 96 spec ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiger_Si »</TD></TR><TR><TD CLASS="quote">mine is at 5800 rpms</TD></TR></TABLE>
Yep, thats where its at.
My tach is off, VTECh looks to come one at 6k for me..... All tach's are off to a certain degree. I think the biggest thing to worry about is rev limit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">My tach is off, VTECh looks to come one at 6k for me..... All tach's are off to a certain degree. I think the biggest thing to worry about is rev limit.</TD></TR></TABLE>
True. What seems weird to me is the fact that before the car got stolen, I remember VTEC engaging and my cluster indicating that my revs were somewhere in the 5,700 RPM range(give or take, it has been over a year). When the rev limitor would kick in, the tach would indicate 8,700 RPMs.
Now that my car got stolen, cluster harness got cut, and I am running a JDM ECU(couldn't find a 97 ITR ECU at the time), my tach indicates VTEC kicking at 6,100-6,200 RPMs. I didn't attempt to see what it indicates when the rev limiter kicks in. I guess after resoldering the cluster wire harness, the solder has added more resistance, and it is off even more now (I am still using my original cluster). That or the effin thieves kicked the cluster around a couple times before the cops showed up and found it on the ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam »</TD></TR><TR><TD CLASS="quote">in for pics!! yea JDM vtec ecu is 5800rpm
i found that with the 8550 oem rev limit, it actually showed on rev counter 9,000 rpm.</TD></TR></TABLE>
Yep 5800rpm for me, Rev limit looks like 9100rpm for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDan »</TD></TR><TR><TD CLASS="quote">and why would you not drive your car for 15 months? </TD></TR></TABLE>
My 97R got stolen/stripped March 2007...sat in the garage until I started to actually work on it new years and it is finally getting close to finished.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam »</TD></TR><TR><TD CLASS="quote">in for pics!! </TD></TR></TABLE>
I have a rebuild thread, but all the pics were on We-Todd and are now gone/lost. I will have to pull my old computer out and upload/update the rebuild thread.
So the JDM ITR ECU has a slightly higher rev limit (8,550 verse 8,400 USDM)? I am assuming it is safe for a completely stock B18C5 to rev to 8,550?
Thanks for all the input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
2. Yes, it does have an oil pressure sensor.</TD></TR></TABLE>
My JDM GSR didn't have one.
Just drove her again...looks like my tach indicates somewhere between 9-9,100 for the rev limitor. I forgot how much fun this car is
Now I am curious if my speedometer is off as well. Can anybody verify that a 96 spec ECU has the rev limitor at 8,550 RPMs before I do calculations to figure out what speed I am traveling at redline?
sh!ft
Sep 1, 2009 07:03 PM
Judah
Sep 23, 2003 05:34 PM
