swap into a 95 civic not running right
Old May 10, 2008 | 11:46 AM
spoonlongblock's Avatar
Default swap into a 95 civic not running right
fixed
Modified by spoonlongblock at 2:36 PM 5/12/2008
Old May 10, 2008 | 01:06 PM
icemyst01's Avatar
Default Re: swap into a 95 civic not running right (spoonlongblock)
i know its basic check your wires make sure you have them in correct order, also see if you have spark....
Old May 10, 2008 | 06:56 PM
wonder squirrel's Avatar
Check the crankshaft position sensor, or start going through the fuel system.
Old May 10, 2008 | 09:12 PM
gsrhatch2356's Avatar
if you sprayed carb cleaner in there and it ran fine I would be looking at fuel supply and maybe swap out computer with a known good one.
Old May 10, 2008 | 10:56 PM
evndrkr's Avatar
find the 95 gsr fuel map and run it
Old May 11, 2008 | 07:11 PM
S300 sits inside of the stock ecu right. so you still have all the same obd1 connections, so just find you a buddy that you know has a good chipped p28 or p06 or if you can get your hands on one a stock obd1 p72. as long as nothing on the motor is drasticly changed (oversized injectors, ITB's, or stage 3 cams) you should be able to run the car on a stock ecu. the best thing you cpuld do is get you a fuel pressure gauge with the banjo bolt fitting so you know exactly what you are getting.
Old May 12, 2008 | 01:18 AM
icemyst01's Avatar
when i did my LS swap the problem i had at the start was the damn thing was flooded... it took me, and 2 other guys (who have done more damn swaps then i can count) like 2 hours to figure out that it was just flooded.
take your spark plugs out and disconnect your injectors and just turn it over a few times to help clear out some of the fuel. again its basic but sometimes its the basic **** is the stuff that hangs everyone up....
Good luck!
harley78
Dec 22, 2014 03:12 AM
boostin99em1
Jan 18, 2011 09:28 PM
Lmgrcivic
11
Sep 3, 2009 11:59 PM
droppedeg6hatch
Dec 10, 2007 09:08 AM
boost_guy
Jun 4, 2006 01:50 PM
