Auto/Manual Conversion
Old May 10, 2008 | 07:45 AM
XpL0d3r's Avatar
Default Auto/Manual Conversion
I will be doing a mini-me/auto-manual/timing belt job in late June, just have a question on the auto/manual conversion..
Can I use my current automatic pedal assembly and just find a clutch pedal or will I need to get a whole pedal assembly for a 5 speed? For a 6th gen if anyone needs to know.
Thanks
Old May 10, 2008 | 07:42 PM
unieizm's Avatar
Default Re: Auto/Manual Conversion (XpL0d3r)
Yeah you will need the whole 5speed assembly( pedals,clutch master cylinder, hard line or custom line, slave cylinder). The ECU, tranny side mount or can redrill hole to line up (ghetto but works). Wire up the center console lock out switch and reverse lights. I think that's pretty much it. Good luck!
Old May 10, 2008 | 08:47 PM
XpL0d3r's Avatar
Default Re: Auto/Manual Conversion (unieizm)
thanks. I have the master/slave cylinder's ordered, should be here tuesday. I have a y8 head vtec solenoid, y8 manifold, and knock sensor sitting here already. Hopefully getting a tranny and flywheel soon. I don't know if he resides on this site, but a member from ClubCivic is helping me with everything. And he has some parts for me too
Old May 12, 2008 | 07:50 AM
gibsanez's Avatar
The pedal cluster swap is a pain in the ***, but it's worth it.
Old May 12, 2008 | 10:30 PM
XpL0d3r's Avatar
Default Re: Auto/Manual Conversion (gibsanez)
Just bought my self all three pedals for $40.50 shipped. Good deal?
EDIT: Used, but work fine.
Old May 14, 2008 | 06:43 PM
69NOSAJ's Avatar
https://honda-tech.com/zerothread?id=1337459
Old Dec 5, 2008 | 08:50 AM
XpL0d3r's Avatar
been a while since an update, but I don't post here too much..
anyways, Auto/manual swap is done, & mini-me swap is done too
pics later on, I'm not home right now...
Old Dec 5, 2008 | 10:07 AM
Truteno's Avatar
how did it all work out? im lookin to do the conversion myself maybe and how much did it run ya?
jack-gtir
Jun 23, 2007 08:57 AM
helpisneeded
Sep 18, 2005 01:11 PM
BeBe
Oct 7, 2004 07:44 PM
LudeSi-93
Dec 26, 2002 08:04 AM
